plugged up carbs and crappy gas - Triumph Forum: Triumph Rat Motorcycle Forums
Old 01-03-2013, 05:18 PM   #1 (permalink)
I used to have a trophy 5 or 6 years ago, been missing it, but I hesitate to buy any carburetor bike these days because of the gas we have plugs up jets so fast, are people having trouble with this on the Trophy's? thanks bete
ride captian ride
bete is offline   Reply With Quote
Old 01-03-2013, 08:57 PM   #2 (permalink)
Main Motorcycle: 2001 Trophy 1200, T509
Other Motorcycle: Norton Commando MK 3
Extra Motorcycle: 1968 BSA Thunderbolt
I think my biggest concern would be the condition of the carburation BEFORE I got the bike, or how much you're willing to get it to be right on your own. I've had my Trophy for three seasons now and was fortunate that the carburation when I got it was spot on with apparantly clean units. Now all I do is add Stabil to the tank a few days in anticipation of "the last ride" so it gets to the bowls etc and thats it. Have had no issues with gas come spring, or during the riding season for that matter either.
rubber biscuit is offline   Reply With Quote
Old 01-04-2013, 01:23 AM   #3 (permalink)
Main Motorcycle: 95 Sprint 900
davetheworv's Avatar
Other Motorcycle: Are there others???
lol biking used to be so easy,you rode it in spring summer/early autumn,put it away for the winter, then tickled the carbs,gave it choke then kicked it over maybe three times and off you went. such is progress
davetheworv is offline   Reply With Quote
Old 01-04-2013, 10:07 AM   #4 (permalink)
You mean way back when gasoline was gasoline (petrol was petrol). These days in addition to the Stabil in the tanks I drain the Amals on those bikes that have them.
Old 01-04-2013, 11:06 AM   #5 (permalink)
Main Motorcycle: 1999 Triumph 1200 Trophy
Other Motorcycle: Mostly KTMs
Extra Motorcycle: 2011 530 KTM EXCR
Its not all that hard to start a bike once a month,is it?
Even current gas doesnt go bad and plug carbs with just the barest of effort. Start the bike,get it warm,occasionally put some fresh gas in.
Let em sit all winter then take the carbs off and clean em otherwise.
Bikes in shed-(1968 Greeves 360 Challenger.)(2011 530-KTM EXCR-)(2009 KTM 200 XC-W) (2003 DR650 Suzuki.) (1999 Triumph 1200 Trophy.) Nor Cal rider.
Flattrack loon is offline   Reply With Quote
Old 01-04-2013, 11:45 AM   #6 (permalink)
Main Motorcycle: 2000 Triumph Trophy 1200
Extra Motorcycle: 2010 Kawasaki KLR650
I agree. When on the off season I start my bikes up once a month. Gas will not go bad in six months and I have never used stabilizers on the advice of my mechanic. I've never had a problem with the carbs gumming up or causing problems once the regular riding season begins.
Sent from my Nexus 7 using Motorcycle.com Free App
Doug Stanger is offline   Reply With Quote
Old 01-04-2013, 10:00 PM   #7 (permalink)
The only carb bike I have now is a KLR650 it does plug it in 30 days, I have got good at cleaning it, what works best is to drain it after each ride but the carbs on the Trophy are a lot tougher to get at. I will just have to be diligent on on running it regular. thanks for the advice. bete
ride captian ride
Old 01-04-2013, 11:17 PM   #8 (permalink)
Main Motorcycle: Triumph Trophy 3
FoothillRyder's Avatar
Other Motorcycle: '98 Triumph Tiger
Extra Motorcycle: '03 Triumph S3
1. Buy good gas (like Chevron)
2. If you park the bike for long periods, keep it on a battery tender and start it every couple of weeks (at least) and let it warm up.
Nearly all of the currently available 'gas' is at least 10% Ethanol, and if left sitting it WILL separate, and the liquid that is not gasoline will be at the bottom of the tank (where the fuel pickup is). You gotta mix that stuff up every once in a while (rocking the bike back and forth is how I do that), and always before you start it.
#1 above is - in my humble opinion - the reason why I have bikes that have sat for six months without gumming up the carburetors. There really is a difference. Save a few pennies per tank on your gas and you'll pay far more later, whether the payment is in the time it takes you to pull, disassemble, clean and reassemble your carbs, or the money it costs to pay someone else to do it.
- FoothillRyder
AMA# 289558, COP#0001, BIR#47
'97 Trophy 3, '98 Tiger, '03 Speedie
My Blog
FoothillRyder is offline   Reply With Quote
Old 01-05-2013, 04:52 AM   #9 (permalink)
Immoderate Moderator
Legend
Main Motorcycle: '04 Sprint RS
KitNYC's Avatar
Other Motorcycle: 2000 Sprint ST
#1 above is - in my humble opinion - the reason why I have bikes that have sat for six months without gumming up the carburetors.<...>
Actually, speaking specifically of Chevron, it's not just your opinion. Chevron adds Techron, one of the few fuel system additives/cleaners that actually does something, to its gas. BMW sells a re-labeled version of Techron as BMW Fuel System Cleaner. It's good stuff, and buying gas from Chevron is quite a bit cheaper than adding half a can of Seafoam to a tank of someone else's gas.
Cheers,
-Kit
Old 01-05-2013, 12:39 PM   #10 (permalink)
Just out of curiosity, what does your mechanic have against gas stabilizers? And, have you asked him specificly about "warming" up a "sleeping" engine once a month or so? Most mechanics I know including myself advise against this practice. The engine will never get warm enough to evaporate the condesation that forms internally and you will more than likely be shutting it off with a bit inside. No condensation will form in a cold engine that stays cold. Overall I think it's a poor way to keep carbs from gumming up. If you don't want to use a stabilizer I would just drain the carburetors.
gasline plugged? Jamo Classic, Vintage & Veteran 11 05-29-2009 11:18 PM
Riding a plugged tire olRocket Sprint Forum 25 07-24-2008 01:10 PM
Plugged up Don x 3 Trophy 5 06-06-2008 08:10 AM
My can was plugged 2007 RkyMtn Tiger Tiger Chat 2 05-22-2008 04:21 PM
wires plugged into carbs GleaminTwin Twins Technical Talk 12 07-05-2006 05:24 PM
