Trophy 3, do I have a problem? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 3 (permalink) Old 11-16-2012, 01:25 AM Thread Starter
Main Motorcycle: Royal Blue Umph 900
MidnightTrophy's Avatar
This is what I got for measurments.
I also measures HT wires. Number 2 cyl wire came up a bit short on Ohms.
Why primary is 1 Ohm not stated .6 Ohm?
All coils are PVL. Wires made in Germany. seems like PVL as well.
Spark plugs look OK, no fouling or other nonsense.
Cheers!
MidnightTrophy is offline
post #2 of 3 (permalink) Old 11-16-2012, 10:38 AM
Main Motorcycle: 2001 Trophy 1200, T509
Other Motorcycle: Norton Commando MK 3
Extra Motorcycle: 1968 BSA Thunderbolt
Looks pretty close to me, especialy when +10% is figured in. By the way I have two multi meters and one always reads voltage and ohms higher than the other.
rubber biscuit is online now
post #3 of 3 (permalink) Old 11-16-2012, 06:58 PM
Main Motorcycle: Triumph Trophy 3
FoothillRyder's Avatar
Other Motorcycle: '98 Triumph Tiger
Extra Motorcycle: '96 Triumph Sprint
You're fine. Unless you're using a precision setup (with 'kelvin' connections to eliminate the contact resistance) to measure 0.6 ohms, you cannot make that measurement accurately. In fact, that variation you see (1.0 to 1.1 ohms) is entirely due to the difference in resistance of the actual contact between your meter lead(s) and the coil terminal(s).
No worries lad.
- FoothillRyder
AMA# 289558, COP#0001, BIR#47
'97 Trophy 3, '98 Tiger, '96 Sprint
My Blog
FoothillRyder is offline
tach problem 1200 trophy jamiecb Trophy 0 10-12-2011 11:42 PM
Trophy High Beam Problem Nigle Trophy 15 07-03-2010 09:06 AM
'95 Trophy 4 steering problem greentex Trophy 7 01-09-2010 08:15 PM
1996 Trophy 900 Clutch Problem lil dog Trophy 6 11-11-2008 06:07 PM
Trophy 900 ignition problem pnfry55 Trophy 1 03-11-2008 10:05 PM
