Poor Starting - Scottoiler issue? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 4 (permalink) Old 11-04-2012, 10:34 AM Thread Starter
Main Motorcycle: Bonneville t100
Argyll's Avatar
Other Motorcycle: Honda CB1300SA
Extra Motorcycle: Triumph TR25W
The guy that's selling me his bike told me that it sometimes turned over a few times before starting. Having read through a number of posts on this forum I decided to open the fuel cap and try it, in order to see if it might be a vacuum problem.
Well, the engine burst into life instantly (much to his surprise) and I suggested that it might need new fuel/vacuum pipes. He mentioned that he had T'eed in his Scottoiler to the pipe to the fuel tap, and not directly onto the carb, and I wondered if this could cause a lack of vacuum pressure, possibly due to a poor fit at the T.
I forgot to ask at the time, but why do some people tee in the Scottoiler connector and not just take it direct from one of the carbs?
Argyll is offline
post #2 of 4 (permalink) Old 11-05-2012, 12:06 AM
Main Motorcycle: Black '04 Sprint RS
Immoderate Moderator
KitNYC's Avatar
Other Motorcycle: Blue '04 Sprint RS
Scottoilers sure do cause a lot of trouble for devices that are supposed to save labor. I would not run one, personally. Between having lost a chain due to a defective Loobman (and the bad habits I picked up with it) and the sensitivity of the vacuum systems on these bikes, I feel like it's just begging for trouble.
All that said, not having enough vacuum to run the oiler and the petcock may be indicative of further vacuum problems. May not be, but it's something to keep an eye on long term.
Cheers,
-Kit
KitNYC is offline
post #3 of 4 (permalink) Old 11-13-2012, 10:08 PM
Main Motorcycle: My '02 Trophy 1200
ervdrvr1's Avatar
If the bike sets for any length of time, fuel will evap out of the float bowls requiring the engine to turn over a few times for vacuum to open the fuel tap and fill the bowls. Use prime to fill the bowls before starting and you won,t have that problem. Also, get rid of the "T" and run the oiler off another carb by itself.
Happy trails,
Erv
"Life is tough, but it's tougher when your STUPID!" John Wayne
ervdrvr1 is offline
post #4 of 4 (permalink) Old 11-14-2012, 01:44 AM Thread Starter
Argyll's Avatar
Happy trails,
Erv
Seems that might have been the issue - bike had not been used much just recently. Since I've had it, the problem has failed to show.
Argyll is offline
poor starting gets worse hatchetman T3 Sport / Touring Forum 15 04-26-2012 07:35 PM
Poor Starting In Winter musicisinmysoul Hinckley Classic Triples 19 02-18-2010 02:14 AM
Hard starting and poor idle when hot gabsdad8 Classic, Vintage & Veteran 4 09-26-2009 09:53 AM
Poor Starting Scrambler ianscram Air Cooled Twins Talk 5 08-06-2008 10:16 AM
Poor cold starting on 900 jm Trophy 9 03-04-2007 07:09 PM
