What mod's are "must haves" ? - Page 5 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-23-2012, 01:16 PM   #41 (permalink)
Main Motorcycle: 1998 Trophy 1200
Other Motorcycle: TS250
Talking
Just thought I'd give a quick run down all in one spot of what is already installed as well as what's coming soon.
The "Have's"
Genmar risers(I believe)
Corbin seat w/ back rest
Throttlemeisers
K&N Air Filter
Nology Coils
Dynojet kit(Needs uninstalled HORRIBLE MPG's)
Bought but not installed.
Clearview med. screen with prv cut outs.
DID X-Ring chain w/ 19/41 JT sprockets
Grip Puppies
Nelson Rigg soft bag for the rear(clearance item)
I'm planning to rebuild the master cylinder and if that doesn't do it, I'll buy some used busa' calipers and new pads to take care of my ill performing brakes. It's about as cheap to buy used busa parts are rebuild the stock calipers so why not give it a shot.
If this summer goes well, next season I may look into the suspension, the front could use work for sure and the rear probably isn't much better. To me it's always easier to realize an improvement than to judge stock as poor. I put a 929 shock on my old 5th gen VFR and it made a big improvement that I didn't know I needed.
TravisL is offline   Reply With Quote
Old 11-27-2012, 10:43 AM   #42 (permalink)
Main Motorcycle: 1999 Triumph 1200 Trophy
Other Motorcycle: Mostly KTMs
Extra Motorcycle: 2011 530 KTM EXCR
Originally Posted by FoothillRyder View Post
So... Flattrack...
Keep your stock calipers, refurb the system with fresh fluid and rebuild the calipers and cylinders (if needed), buy a set of EBC HH pads and go.
You don't need to replace the calipers.
I dont want to replace the calipers,too busy fooling with dirtbikes to be taking streetbikes apart. Stock brakes are smooth and powerful enough on the 1200.
Bikes in shed-(1968 Greeves 360 Challenger.)(2011 530-KTM EXCR-)(2009 KTM 200 XC-W) (2003 DR650 Suzuki.) (1999 Triumph 1200 Trophy.) Nor Cal rider.
Flattrack loon is offline   Reply With Quote
Old 12-01-2012, 09:18 AM   #43 (permalink)
Main Motorcycle: Triumph Trophy 1200 T300E
Klingone's Avatar
Originally Posted by Klingone View Post
No, Daytona 1000 (only built approx 2 or 3 years in the early 90s). We've got few guys here, who did that already.
I assume, that here in mid of Germany the roads are not as they are in Texas. I'm mostly on short runs here in my region ... wonderful winding roads.
Have a look: http://vimeo.com/42270959
Hi All!
Since a couple of days I've got my Trophy back with new camshafts, rejetted, ignition adaption. GREAT!
Due to the already started winter here in Germany, she's now hibernating
But I'd like to share the sound with you:
Greets, Heiko
Eat more flies - a biker's work is never done
Enjoy a 5 min fast ride on my Trophy, Predator silencers
Klingone is offline   Reply With Quote
Old 12-07-2012, 07:25 PM   #44 (permalink)
Main Motorcycle: My '02 Trophy 1200
ervdrvr1's Avatar
Kit,
All 91 & 92 Daytona's where either 750 or 1000cc. 91/92 Trophy's where 900/1200cc. The 1200 Daytona didn't come out till 93. I think the DE and AU Daytona's had the fabled blue dot cams. 3 different profiles where used. Red daytona, green trophy, and rumored blue daytona that falls between the red and green. I know some trophy owners tried the blue dot 1000 cams with good success. Red cams not so much.
The 1000cc red cams where carried over into the 1200 daytona.
Happy trails,
Erv
"Life is tough, but it's tougher when your STUPID!" John Wayne
ervdrvr1 is offline   Reply With Quote
Tech question- Building a "spy" car, specifically adding "smoke-screen" jjmeadowlark Biker Hang-Out 33 04-14-2013 11:53 AM
Travesty? Cool? Triumphs turned into "Choppers" and "Bobbers" S3 Street Rat Biker Hang-Out 46 07-14-2011 12:56 PM
Combining my "seat heat" and "tune" threads here TheNomad Sprint Forum 10 06-02-2008 12:09 PM
"Mod's" with a new attitude! Thrux-ton-up Club Cafe' 18 11-02-2007 12:05 PM
