Originally Posted by two wheels only
I have tried to contact bikebandit but they want triumph p/n's and i cant seam to find a micro fisch that has p/ns. Can you help?
How were you trying to contact them?
Bike Bandit has illustrations on their website when you select to look for OEM parts. You select Truimph, Then you have to select the year and model of your Triumph, and the website takes you to the parts manual where you select the parts from the illustrated parts guide.
http://www.bikebandit.com/1996-triumph-trophy/o/m17544
As far as the carbs you have on your bike, there should be info stamped on them that should help.
You may need the VIN from your bike to identify which parts you need.
That should be all the help you need, especially if you're someone who can rebuild your own carbs.
