Gear ratio - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 10-25-2012, 04:40 PM   #1 (permalink)
Main Motorcycle: Royal Blue Umph 900
MidnightTrophy's Avatar
Gear ratio
Hey All!
Guys chime in what gear ratios (sprockets) you have or currently run.
I'm thinking to go +2 front -1/2 rear to lower hi way RPM.
Thanks in advance.
MidnightTrophy is offline   Reply With Quote
Old 10-25-2012, 08:35 PM   #2 (permalink)
Main Motorcycle: 2012 Bonneville SE
Other Motorcycle: 2010 BMW F 800 ST
Extra Motorcycle: 2007 Suzuki DL650
I believe you're moving the wrong way. You need to drop a tooth on front and/or drop a tooth in the back to drop revs @ speed.
J Goertz
Birmingham, AL
Trophy4 is offline   Reply With Quote
Old 10-25-2012, 10:33 PM   #3 (permalink)
Main Motorcycle: 2001 Trophy 1200, T509
Other Motorcycle: Norton Commando MK 3
Extra Motorcycle: 1968 BSA Thunderbolt
Wink
No, with out getting into combinations of counter shaft/drive sprocket ratios, adding teeth to the countershaft sprocket will drop revs per mph in all gears, as will dropping teeth on the drive sprocket.
rubber biscuit is online now   Reply With Quote
Old 10-26-2012, 12:45 AM   #4 (permalink)
Main Motorcycle: Triumph Trophy 3
FoothillRyder's Avatar
Other Motorcycle: '98 Triumph Tiger
Extra Motorcycle: '03 Triumph S3
Biscuit is correct. Reducing the tooth count on the countershaft sprocket increases the numerical ratio (increasing the engine RPM for a given road speed), while reducing the tooth count on the drive sprocket reduces that ratio with a corresponding drop in RPM for a given speed.
- FoothillRyder
AMA# 289558, COP#0001, BIR#47
'97 Trophy 3, '98 Tiger, '03 Speedie
My Blog
FoothillRyder is offline   Reply With Quote
Old 10-29-2012, 11:14 AM   #5 (permalink)
Main Motorcycle: Yamaha FJR1300AS
Originally Posted by MidnightTrophy View Post
Hey All!
Thanks in advance.
Try my gearing calculator here.
You can play tunes with the sprockets.
mcatrophy
'10 FJR1300AS [ex '06 FJR1300AS, '02 Trophy 1200, '01 Bonneville, '55 Tiger Cub]
http://atrophy.lock.net
mcatrophy is offline   Reply With Quote
Old 10-30-2012, 06:11 AM   #6 (permalink)
Guys we're going off track here.
DRIVEN(rear sprocket)
----------------------------- = FINAL RATIO
DRIVE(front sprocket)
Apply final ratio numerical figure to transmission ratio(s), you'll have individual gear final ratio.
The higher, numerically, tooth count on a DRIVEN gear, the higher the RPM at any given speed. The lower, numerically, tooth count on DRIVE gear, the higher RPM at any given speed.
But this is all irrelevant...All I was asking about the real experiences of having numerically different sprockets front/back...
Any real cases of "gear change" and how it affected your riding experience?
Cheers ...
Old 10-31-2012, 03:01 AM   #7 (permalink)
Main Motorcycle: 1998 Trophy 1200
Other Motorcycle: TS250
This doesn't help much, but from the digging I've done I'm going to try going with a 19/40 combo.
TravisL is offline   Reply With Quote
Old 10-31-2012, 03:44 AM   #8 (permalink)
Main Motorcycle: Speedtriple!!
triplestrength's Avatar
Other Motorcycle: Triumph Trophy 900
Extra Motorcycle: Honda CB400AT
I use 1200Trophy gearing on my 900 it works out to 4500rpm at 70mph which suits me really well it improved the fuel economy a little but for me because I was doing a fair amount of motorway riding, the drop in revs stopped the bike feeling buzzy.
It's a 19 tooth on the front. Can't remember the rear but it was whatever was stock for the 1200.
Sent from my GT-I9100P using Motorcycle.com Free App
triplestrength is online now   Reply With Quote
Old 11-01-2012, 12:24 AM   #9 (permalink)
Main Motorcycle: 1999 Triumph 1200 Trophy
Other Motorcycle: Mostly KTMs
Extra Motorcycle: 2011 530 KTM EXCR
Its been a bit of a toss up for me,I like the gearing Ive got on the bike on backroads,but then its revving 4 grand at 70 mph,it seems like a 1200 should be able to loaf along at 2500 rpm on the hiway.
But really,to pass quick the thing should be revving at 3500 or 4 grand to whoosh past cars,its a 4 cylinder and seems real smooth at 4 grand and still gets over 40 mpg doing so. Im not so sure gearing it way taller would help with mileage that much.
I do like the acceleration as the gearing is.
Guys who have geared it taller,does it get much better mileage?
Bikes in shed-(1968 Greeves 360 Challenger.)(2011 530-KTM EXCR-)(2009 KTM 200 XC-W) (2003 DR650 Suzuki.) (1999 Triumph 1200 Trophy.) Nor Cal rider.
Flattrack loon is offline   Reply With Quote
Old 11-01-2012, 10:23 PM   #10 (permalink)
I think the stock gearing is the best over all for most conditions, at least where I live. Most of my riding is pretty curvy badly surfaced secondary roads with a lot of elevation changes. There is a lot of slowing down and speeding up. On some of these roads 50 to 60 mph is a good pace and with the stock ratios there is a minimum of back and forth shifting. The few times on a highway I think sure the revs could drop a lot and the bike could easily mantain speed, but the compromise would be less than ideal on the roads I usually ride. If most of my riding was out west with long sweeping 70,80,90mph roads I probably would add a tooth or two to my countershaft sprocket. But give your riding area and road type a serious look and don't change gearing just for change sake.
T140 Tach gear ratio? Autotek Classic, Vintage & Veteran 2 07-23-2012 11:46 PM
Speed/gear ratio Splittie65 Classic, Vintage & Veteran 2 01-24-2012 02:15 PM
primary gear ratio? onewheelwonder Sprint Forum 3 12-08-2011 12:34 PM
2001 TT600 Gear Ratio Numbers? TLCS3 Triumph SuperSports 2 07-14-2008 09:09 PM
Gear ratio?? TrackerOldGuy Speed Triple Forum 22 07-26-2006 02:20 PM
