Gear ratio - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-02-2012, 03:09 AM   #11 (permalink)
Main Motorcycle: 1998 Trophy 1200
Other Motorcycle: TS250
If I lived in the hills with lots of twisty bits I'd be less concerned about gearing it for the highway. But I live in Iowa, lots of open 4 lane roads(i.e. boring) and I usually ride at 65-75mp all the time. If I'm running 4 lanes it's frequently a bit faster yet.
I've also not achieved 40mpg so far. I bought it with a "stage 1" jet kit, averaging about 80mph I returned about 23mpg.......
TravisL is offline   Reply With Quote
Old 11-04-2012, 01:33 PM   #12 (permalink)
Main Motorcycle: 2001 Trophy 1200, T509
Other Motorcycle: Norton Commando MK 3
Extra Motorcycle: 1968 BSA Thunderbolt
Exactly what I was getting at. The type of riding you have would have me looking at taller gearing too. Starting out in first would be an only limiting factor. Too much clutch slippage just to get moving is not good. Even with the higher speeds you run at though 23 mpg doesn't sound right even with stock gearing. What actually does a "stage 1" jet kit entail? I've not had the "pleasure" of having to inspect my carbs so I don't know what's in there for jets or the needle position but I have no drivability issues and am returning just about 40 mpg.
rubber biscuit is offline   Reply With Quote
Old 11-14-2012, 01:04 AM   #13 (permalink)
Main Motorcycle: My '02 Trophy 1200
ervdrvr1's Avatar
19/40 is the tallest gearing you can get for the Trophy. I don't think a 20 tooth sprocket will fit in the housing, and I haven't found anything smaller than 40 that will fit the rear. For the 1200, this is probably the best overall gearing unless you're an acceleration freak. This may be a little to tall for the 900 unless you ride solo and lightly loaded. Maybe 18/40 or 19/43 would probably be as tall as I would go with the 900.
Travis, don't know who trashed your carbs, but you should be getting much better mpg's than that. Is this a 900 or 1200? If no other mods have been done, I would return to stock jetting. 2-up, loaded heavy and pushing hard I get 36mpg out of my 1200.
Happy trails,
Erv
"Life is tough, but it's tougher when your STUPID!" John Wayne
ervdrvr1 is offline   Reply With Quote
Old 12-07-2012, 03:15 PM   #14 (permalink)
I am currently running a 19/42 set on my 1996 Trophy 1200, and on solo trips am hitting around 48 mpg. 2-up drops it to around 42-43. This is "normal" riding, when I get on it, it drops to 38-39.
1995 900 Sprint Nightshade
1996 1200 Trophy Merlot
TxGr8WHite is offline   Reply With Quote
Old 12-15-2012, 08:28 PM   #15 (permalink)
Main Motorcycle: '96 Trophy 900
BonnieRider's Avatar
Other Motorcycle: '01 Bonneville
Extra Motorcycle: '77 XLCR 1000
My 96 900 came with 17/43. Currently I have 19/40, but I am going to go back to (US) stock with my next chain. I find that I am always riding in a lower gear.
The 19/40 was stock for certain markets, but I feel it has changed the ridability of the bike too much. Probably fine if all you do is open highway riding.
Steve
96 Trophy 900
BonnieRider is offline   Reply With Quote
T140 Tach gear ratio? Autotek Classic, Vintage & Veteran 2 07-23-2012 11:46 PM
Speed/gear ratio Splittie65 Classic, Vintage & Veteran 2 01-24-2012 02:15 PM
primary gear ratio? onewheelwonder Sprint Forum 3 12-08-2011 12:34 PM
2001 TT600 Gear Ratio Numbers? TLCS3 Triumph SuperSports 2 07-14-2008 09:09 PM
Gear ratio?? TrackerOldGuy Speed Triple Forum 22 07-26-2006 02:20 PM
