speedo cable? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-18-2012, 02:31 PM   #1 (permalink)
Main Motorcycle: triumph trophy 900
speedo cable?
my speedo has stopped working out of the blue and suspect the cable, undo it from the front tyre end and cleaned a bit of gunk out and twisted it around with aid of screw driver to see if it worked and no result ....
so now is my problem taking it off from the speedo end with out taking off all the fairings etc as to be honest not that good. tried to get an adjustable spanner in there but struggled.
any ideas?
badge73 is offline   Reply With Quote
Old 08-18-2012, 04:07 PM   #2 (permalink)
Main Motorcycle: 99 Trophy 1200
Mark62's Avatar
Other Motorcycle: 79 Honda CB750F
You should be able to grab it with some pliers. Did you take the black inner fairing off?
Mark
Mark62 is offline   Reply With Quote
Old 08-20-2012, 08:17 AM   #3 (permalink)
no mark, think i could reach in with pliers though .... i presume just twist it off? or does it unscrew?
do like my trophy but just a pain to have to take the fairings off for most repairs, and obviously when it goes to the garage most of the labour is taking the fairing on and off.
Old 08-20-2012, 11:05 AM   #4 (permalink)
Main Motorcycle: 2000 Triumph Trophy 1200
Extra Motorcycle: 2010 Kawasaki KLR650
The speedo cable unscrews from the bottom of the gauge. You do have to "get the feel" for positioning your hand and arm right but it can be done without removing any of the fairing. I found this out when twice my speedo stopped working and it turned out to be the female threaded nut holding the cable in place vibrated loose from the gauge. The first time it happened it took awhile cursing while I felt around but the second time it only took a few minutes to screw it back into place and then get some pliers on it.
Doug Stanger is offline   Reply With Quote
speedo cable fix motomofo Speed Triple Forum 1 02-04-2011 02:44 PM
Where to get new speedo cable? Craigore Twins Technical Talk 4 07-26-2010 07:12 PM
speedo cable streetfighter Speed Triple Forum 1 06-24-2008 07:57 PM
speedo cable blackedout Twins Technical Talk 5 12-31-2007 04:18 PM
Speedo cable Copper Twins Talk 3 08-06-2005 08:46 PM
