side stand worry - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-04-2012, 06:44 PM   #1 (permalink)
Main Motorcycle: Triumph trophy 900
side stand worry
Hi all.
My 1996 trophy 900 sits very low on side stand, it seems to be the fork configuration that attaches the stand to the bike in that over time the fork has opened up to make the bike sit rather low to which I'm fearful that it could snap.
Has anyone come across this and found a remedy like using a side stand from another bike.
I did think about removing stand and trying to close the top end of the stand but again worry it could weaken stand and one day the bike would collapse with a crash.
Any ideas welcomed.
Thanks in advance.
Twinnyboy is offline   Reply With Quote
Old 07-04-2012, 07:17 PM   #2 (permalink)
Main Motorcycle: 99 Trophy 1200
Other Motorcycle: 2003 Yamaha FJR 1300
The earlier (thru98?) models had a short sidestand. You can cut and splice and make longer or get one for a 99+ and it is about 1 1/2 inches longer.
http://www.triumphrat.net/trophy/163...ide-stand.html
Goody is offline   Reply With Quote
Old 07-04-2012, 11:15 PM   #3 (permalink)
Immoderate Moderator
Legend
Main Motorcycle: '04 Sprint RS
KitNYC's Avatar
Other Motorcycle: 2000 Sprint ST
First I've heard of a longer stand being available, but I have firsthand experience with a bent bracket on a '96 Trident (and the associated mirror, lever, signal, etc., replacements...). It looks like shimming the stand or closing up the clevis the stand attaches to will fix it, but it won't. The front of the bracket will have bent a bit to the right, and will bend a bit more as more weight is placed on it, 'til it won't hold the bike up at all anymore. The solution is a beefier bracket from an '01-up Trophy. (Or so I've been told; it's actually VIN 55072 and up.)
One of the bolts that holds the bracket on screws into the case or the frame or something, but the other has a (19mm? head) nut on it that you can't see. Much easier to swap brackets if you know that nut is there...
Cheers,
-Kit
Old 07-05-2012, 04:09 AM   #4 (permalink)
Newbie
I've done the same bracket and stand swap out on my '96 1200. She leaned a little too far for my liking. I tried to shimmy, etc... and had mixed results. I got mine from an '02 on fleebay. Works like a charm!
Jordan
terayon is offline   Reply With Quote
Old 07-11-2012, 12:03 PM   #5 (permalink)
Originally Posted by Twinnyboy View Post
Hi all.
Any ideas welcomed.
Thanks in advance.
My 96 1200 also leaned too far and depressed asphalt paving. I made a shoe for the stand; a larger area 1/4" thick plate with 3 vertical posts (nails) welded to it. I then bent the nails around the foot and used epoxy clay to smooth and secure the shoe. Grey spray paint and it looks like it was part of the bike. Care must be taken to shape the plate to clear the muffler when in its up position.
mdapple is offline   Reply With Quote
Center stand and side stand nfldrunner Hinckley Classic Triples 23 01-25-2010 11:50 AM
Side Stand or Centre Stand??? dryheat Twins Technical Talk 14 08-12-2008 05:47 PM
Chain adjustment-center stand or side stand? andyc740 Trophy 7 04-02-2008 05:41 PM
shorter side stand (kick stand) ? TriumphTT_2 Triumph SuperSports 6 06-07-2007 06:04 PM
Center stand and side stand wanted Sprint Forum 1 01-21-2004 08:38 PM
