Clutch life - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-07-2004, 11:40 AM   #1 (permalink)
I'm new around here, I bought a 96 trophy with around 6500 miles on it. I love the bike but I have never had a bike with a hydraulic clutch before. It seems to grab a little farthet than I would expect and I was looking for a ball park life span of a clutch for this bike,or might there be a simple adjustment? The fluid looks to be correct. but I was just woundering?
Don
Old 04-07-2004, 02:20 PM   #2 (permalink)
Favourite Bike: Roadking
ok first of all anybody here will tell you these clutches in these bikes are built pretty good and the life span if used without any abusive use will last well over 20000 miles and the travel on this type of clutch is at the top of the lever travel cable types are more closer to the grips but not as smooth
shedds is offline   Reply With Quote
Old 04-07-2004, 05:05 PM   #3 (permalink)
Favourite Bike: 2002 Triumph Trophy
Other Motorcycle: 1970 Triumph Tiger 650
Extra Motorcycle: 1999 Yamaha Virago 1100
Just a thought..is the lever adjustable for "reach"? My 02 has 4 settings on the lever to compensate for the size of one's hand. If you haven't checked it out, that might be a help to you.
Regards: Jim
Jim Ballard
jimballard is offline   Reply With Quote
Old 04-08-2004, 11:04 AM   #4 (permalink)
Tanks guys The lever is set @ 3 I might try adjusting.
Don
Old 04-30-2004, 07:12 PM   #5 (permalink)
Shredds,
Did you mean 200,000 miles on the clutch? Because 20,000 miles is way too low for a clutch to need replacing. I'm new to Triumph but the clutch on my Concours was still perfect at 102,000 when I sold her.
Old 05-01-2004, 11:40 AM   #6 (permalink)
Favourite Bike: '98 Triumph Sprint Ex.
Extra Motorcycle: '02 Kaw Ninja 250
Don,
The clutch on my Sprint Executive 900 is the same as the clutch on your Trophy. At 65,000+ miles my clutch shows no signs of wear. I suggest you do a fluid change to keep things smooth.
j98sprint
j98sprint is offline   Reply With Quote
Life span of clutch gm16sw Twins Technical Talk 2 12-28-2007 01:47 AM
Ruined for life, please help! DesertRunner Twins Talk 68 11-28-2007 03:19 AM
Could we have some life Tricks RAT - United Kingdom 37 09-10-2007 05:30 PM
clutch life. speedblastr Twins Technical Talk 3 06-24-2007 12:39 AM
got to go to this once in your life for sure . runtheton Twins Technical Talk 16 04-05-2007 12:19 AM
