Old 11-09-2005   #1 (permalink)
Does anyones gas gauge actually work?
"The Glory of God is man fully alive."
narrowminded is offline   Reply With Quote
Old 11-09-2005   #2 (permalink)
Other Motorcycle: '07 Big Dog Pitbull
I have never had a problem with mine. I start getting signs of needing to go to reserve when it gets to the red and everything. The only way to get the tank actually full is to fill it up while holding the bike upright or on the center stand. What issue are you having?
[ This message was edited by: rat2tymes on 2005-11-09 22:18 ]
Clever quote goes here
rat2tymes is offline   Reply With Quote
Old 11-10-2005   #3 (permalink)
This girls gauge is all over the place. Reads full, 10 minutes later 1/4 tank, then up to 3/4 and down to empty. Totally unreliable, I use the trip odometer to tell me the fuel level.
Old 11-10-2005   #4 (permalink)
Kinda sounds like a loose wire.
Mine does change quite a bit when I rock the bike(gas is moving back and forth) and when its upright, it will read 3/4 but on the side stand, it will read1/4, but I'd say thats normal. For the most part its reliable when going down the road. I think they started putting baffles in the tanks to prevent this though.
cs
witecap4u is offline   Reply With Quote
Old 11-10-2005   #5 (permalink)
Favorite Bike: 2000 Triumph Trophy 900
Mine works, it's just not the most accurate thing in the world. same situation as whitecap described.
Scott
Ride, Eat, Sleep, Repeat.
trophyrider00 is offline   Reply With Quote
Old 11-10-2005   #6 (permalink)
mnmrosen's Avatar
I believe they're all like that. No damping effect, so every stop, go and turn causes the needle to jump. You should get a steady and reasonably accurate reading when moving at a steady speed, however.
1996 Triumph Trophy 900
2003 Kawasaki KLX400SR
mnmrosen is offline   Reply With Quote
Old 11-10-2005   #7 (permalink)
Favorite Bike: 2002 Triumph Trophy
Other Motorcycle: 1970 Triumph Tiger 650
Extra Motorcycle: 1984 Yamaha Virago 700
Miine goes to 1/2 full in 60 miles, then it takes another 120 or so to go below 1/4. So....if you haven't already guessed, I use my trip odometer for the most part.
"Fuel" for thought: Jim
Jim Ballard
jimballard is offline   Reply With Quote
Old 11-10-2005   #8 (permalink)
Mine works consistently, but I go more by mileage anyway.
davie.
I,ve got a mountain of dreams to climb.
Do unto others as they are doing unto you.
tango is offline   Reply With Quote
Old 11-10-2005   #9 (permalink)
Mine actually works great on my 900. Consistantly, I get 50 miles on the first quarter, another 50 on the second, another 50 on the third, and by the time I'm hitting 200 miles, I'm getting close to having to switch to reserve.
yes, it has the bobbing needle effect from 1/2 to 3/4 ranges, but outside of that, it's pretty darn close.
porsche996 is offline   Reply With Quote
Old 11-10-2005   #10 (permalink)
Ripper
Mine is like Jim's. less than 50 mile to the half way mark, but about 100 mile in the bottom half. By the sape of the tank you'd think it would be the opposite
Gas gauge acting up Tee-Dub Speed Triple Forum 6 09-13-2006 10:26 PM
Gas Gauge? SamboGARN Twins Technical Talk 29 08-26-2006 02:58 PM
Gas Gauge on '02 ST Panthers_Den Sprint Forum 7 01-10-2006 04:45 AM
Gas Gauge on '02 ST Panthers_Den Sprint Forum 16 09-20-2005 12:39 AM
Gas gauge?? MontrealMike Triumph SuperSports 7 05-23-2005 03:27 PM
