Hi Dogg,
Silly question: Are you sure that the choke is pulling all the way off? That will cause the problem if it is on just a slight bit. Also, the tip-over valve on the fuel tank vent may be sticking. I've had both of these problems on my '02 1200.
Hope this helps a bit: Jim
Jim Ballard
