trophy oil leak - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Old 04-04-2004, 07:22 PM   #1 (permalink)
i just bought a 1998 trophy and much to my dismay i found out it has a small oil leak. it looks as if it is leaking around the output shaft (sprocket end) i have not taken the cover off yet but it looks as if this is where it is coming from. can this seal be replaced without breaking down the case?........also how many miles can i expect from a set of brake pads. thanks for any help you can give on this matter.
Old 04-06-2004, 02:20 PM   #2 (permalink)
Are you sure it's an oil leak? chain fling can collect in this area and look like an oil leak
stevent....."May the Goddess turn the hearts of those who hate us, if not their hearts then turn their ankles so we'll know them by their limping..."
stevent is offline   Reply With Quote
Old 04-06-2004, 06:22 PM   #3 (permalink)
I have the same thing on my Sprint and the oil is definately coming off the chain (maybe I should turn the scotoiler down!!).
Better to be over the hill than under it!
Toothpick is offline   Reply With Quote
Old 04-07-2004, 10:50 AM   #4 (permalink)
Favourite Bike: Roadking
it sounds like the sprocket shaft seal to me i just had mine replaced after believing it was chainlube, they had to replace the seal and bushing together what happens is chain gets too tight and forces the seal and bushing to wear on one side causing a leak good luck
shedds is offline   Reply With Quote
Old 05-02-2004, 11:33 PM   #5 (permalink)
thanks to all for the info on this oil leak....upon further in investigation i found it was the output shaft oil seal so i did put a new one in.......i haven't ridden it yet so i hope this was all it was.hopefully the shaft bearing is o.k. (i guess if it is bad it could cause the seal to fail prematurely) thanks again!!!
Old 05-07-2004, 08:07 PM   #6 (permalink)
I changed my '96 1200 rear pads at 12k and just changed my fronts at 21k (backs still look good). Put sintered (sp?) on both.
tmccullion is offline   Reply With Quote
Coolant leak at start up on 2002 Trophy. VTXED Trophy 5 10-31-2007 05:21 PM
Oil leak, right-side oil cover Rincewind Tiger Workshop (archive) 2 05-30-2007 11:36 PM
oil filter seal failure - oil leak / spray mlc Twins Technical Talk 7 05-25-2007 04:09 PM
Trophy 900 Fuel Leak countrysportsuk Trophy 2 10-24-2005 05:08 PM
Oil leak->Gasket/Oil change->won't start Hinckley Classic Triples 6 11-25-2004 09:43 AM
