Cannot say I have experienced a water vapour problem but as for visability I found the panel lights bloody hopeless so installed two 1" round orange LED accessory indicator lights, in the area above each of the storage compartments, and then fitted another bright white indicator light in the center area below the indicator panel, that comes on when in neutral. Now at a slight glance I can see what is on.
