What happens when you let go of the throttle and let it snap shut? Does it affect return to idle? If it does, you might try pulling the tank and make sure the return springs on the shafts aren't fouled with dirt and road grime.
If they are, clean them with a good flushing of WD-40 (Stay away from solvent sprays as they can cause carb shaft o-rings to swell) and blow dry with compressed air, then spray a good silicone lubricant on the springs and shafts.
Life's too short to ride Jap bikes!
