nology coils? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 10 (permalink) Old 05-13-2011, 11:58 AM Thread Starter
Main Motorcycle: '98 Trophy 1200
Send a message via AIM to Simstud
nology coils?
Everyone here seems to agree that nology coils are the best. But which ones and where do you get them? The nology website doesn't have a listing for triumph. I can buy 3.0 ohms and 0.3 ohms, but the stock coils are 0.6 ohms.
Simstud is offline
post #2 of 10 (permalink) Old 05-14-2011, 08:24 PM
Gerrit657's Avatar
coils
Here is one place that has them.
http://store.newlevelmotorsports.com/noprigcofort.html
Dreaming again
Gerrit657 is offline
post #3 of 10 (permalink) Old 05-19-2011, 01:55 AM
Main Motorcycle: Trophy
penguinchicken's Avatar
Other Motorcycle: 68' CL125A
Extra Motorcycle: 81 Suzuki fs50
http://www.nology.com/profire.php#Motor
PFC-06TD - 0.6 Ohm, Dual Outlet 152 001 070T
I put these on my 00' 1200. Direct bolt on. No modding required.
There website is sort of sucky there...you have to click on the "buy now" button under the pro fire motorcycle tab.
penguinchicken is offline
post #4 of 10 (permalink) Old 05-19-2011, 04:40 PM
Main Motorcycle: T312 Trophy 2002
Rookie111's Avatar
Other Motorcycle: Sprint ST 955i
Hi all i know you guys are in the states but try this site for good parts
www.triumphparts.co.uk
blessed are the cracked for they let in the light
Rookie111 is offline
post #5 of 10 (permalink) Old 05-20-2011, 10:40 AM Thread Starter
Thanks guys I ordered some from new level motor sports, because I didn't see that I could oder them from directly from nology. Thanks again.
Simstud is offline
post #6 of 10 (permalink) Old 05-29-2011, 03:04 PM
NITES's Avatar
Other Motorcycle: 1996 Trophy 1200
Extra Motorcycle: 99 Kawasaki Drifter 1500
Bought mine at New Level awhile back. I called and the guy confirmed which ones they were and had me order online. He gave me a code to put in and I got $10 off, free shipping, and some free grips I put on another bike. Got everything in 4 days. Nice place to do business with.
NITES is offline
post #7 of 10 (permalink) Old 06-07-2011, 03:04 PM
Main Motorcycle: Triumph Trophy
This is good info.. How difficult is it to replace the coils on an 01 1200?
dcampbell is offline
post #8 of 10 (permalink) Old 06-07-2011, 03:52 PM
Main Motorcycle: 2008 T100 Bonneville
Fairly simple. Got a manual? With good pictures and instructions it took me about an hour with hand tools on my 1999 1200.
Goody is offline
post #9 of 10 (permalink) Old 06-07-2011, 08:16 PM
NITES's Avatar
I have a 96 Trophy 1200 and recently did the coils, I'm not sure if its exactly the same but should be very close. I'll give you a quick rundown and hope it is of some value.
The job is easy, I can do in about 30 mins usually. Just make sure you have the tools. Each coil is held on by torx (star shaped, size 20 I think???) headed screws so make sure you have some ready. Get a few pieces of scrap wood about 4 inches long and a stick about 12-18 inches long. You can use the wood to help prop up the tank so you don't have to totally disassemble everything. You'll also need a small ratchet with sockets and a few allen wrenches.
The way I do it:
1. Unlock the handlebars so they move freely. Put bike on center stand (if possible). Remove the seat
2. Take off the two screws under the seat that hold the rear tailpiece to the frame.
3. Carefully (Very carefully) pop out the front of the tailpiece (toward the center of the bike where they meet the tank). Each side is supported by 3 plastic pins that fit inside rubber grommets. They break easily if not careful.
4. Wedge a piece of wood between the tailpiece and the airbox to help spread the plastics outward about 3" each.(enough to use tools in there)
5. Under the tank where it meets the seat, you will see a black bracket that mounts the tank to the frame. Use a ratchet and take off the six horizontal screws (3 on each side) that are there.
6. Put a towel over the battery to prevent the tank from touching the terminals. Very carefully, slide the tank back towards the battery (about 3 inches). You will feel the front of the tank unhook
7. Carefully grab the front of the tank and lift upwards and back. Use a thin stick or piece of wood to prop up the front of the tank. (as if you're propping up a box with a stick to capture an animal). You should make sure that your tank is propped up safely so you can walk away and have room to work underneath it.
8. You will see the coils are mounted right there to the frame with torx bolts. Unclip one wire plug on the old coils. Take a look at the tip on the old coil and see if it is threaded or smooth (like a spark plug) It should be threaded. The Nology coils come with smooth pin adapters installed. Take them off with pliers. Make sure you put each wire in the proper place on the Nology coils because they have a firing order to each cylinder. Then you can take off the old coils and bolt the new ones in.
9. After the coils are in, remove the stick and lower the front of the tank. Then slide the tank forward and you will feel it lock in place.
10. If your bike has a fuel cutoff switch on the left side, make sure that the fuel hoses and the air vent hose to the petcock, did not kink. If any of the 3 hoses are kinked, the bike will not start because it won't get the right fuel/air to the carb.
11. Put back in the 6 screws for the tank mount.
12. Remove the wood blocks and put the plastic pins back in for the tail section. Also put in the 2 screws that hold the plastic to frame.
13. Put on the seat and start it up. Should start pretty fast because these coils are alot stronger than stock Gills brand.
Hopefully it all goes smoothly for you. Let us know how it goes and Good luck to you.
NITES is offline
post #10 of 10 (permalink) Old 08-06-2011, 02:28 PM
NITES's Avatar
Yes that's right.
1 & 4 are on the clutch side coil
2 & 3 are on the throttle side coil
NITES is offline
nology coils customclint Hinckley Classic Triples 8 01-24-2010 01:48 PM
Nology Coils Studog00 Hinckley Classic Triples 13 11-29-2006 11:22 AM
new Nology coils ronniena Hinckley Classic Triples 4 08-12-2006 05:45 PM
Nology coils ronniena Hinckley Classic Triples 1 06-11-2006 02:33 PM
Nology Coils ? which one bikerjim Trophy 2 07-14-2005 12:34 PM
