Progressive Insurance
britishcustomsSpringfield ArmoryTriumphPerformanceUSAAmericanMotorcyclistAssociationMotorcycle.com Classifieds!SportbikeTrackGearCycleGear.comAdvanstarMotorcycleShowsAnnitori Distributing
Old 09-20-2005   #1 (permalink)
charbuild
Smooth road, decelerating on downgrade at 55mph, one up, 3 bags(loaded),tank bag, new rubber and new rear brakes. Bike went into a progressive tank slap- tossing me. Bike slid to a stop neither of us striking objects. Damage was minimal and I am now in the process of having it repaired. Dealer found a top right tripple clamp and lower left clamp loose but could not tell if this was the cause of the head shake as the loosening may have been caused by the wreck. As I don't wish to repeat this maneuver I would like to install a damper but can not find much info about an installation on a newer trophy. Anyone else had this problem or am I the only lucky one?
Old 09-20-2005   #2 (permalink)
Favorite Bike: 2000 Triumph Trophy 900
First off Charbuild, I am glad you are okay. I only had one experience with a tank slapper on an old Harley I had where one of the motor mounts had broke. I have never had one on my Trophy and I have actually had my hands off the bar while slowing down to see if one would start. I have ridden many time like you, all three bags full, tank bag, and one up. When I saw you posted you had new tires, my thinking went to there as the probable cause. Were the wheels balanced?
Scott
Ride, Eat, Sleep, Repeat.
trophyrider00 is offline   Reply With Quote
Old 09-22-2005   #3 (permalink)
TriumphSTRider
Mine caught me off-guard once too. Luckily I didn't go down, but it sure got my attention. I was slowing down, going like 30 MPH, and took my hands off the bars for a second. Shook like a bastard...
At the next service, I asked them to check the triple clamps and wheel balance. All checked out fine. They did suggest a new tire, since nothing else seemed to fix it. Sometimes a belt within the tire can break and cause head-shake.
Sure enough, replaced the tire, and the shake is gone. I don't know if the same problem can happen with a brand new tire, but it might be worth checking - maybe they can replace it on warranty.
Old 09-26-2005   #4 (permalink)
I found that the trophy has a tank slapper tendency around 40mph. I know a few people that own these and they all have the same oscillation on the bars around 40-50mph. I found that putting on the Metzler Z6 tires got rid of a bunch of it. Previously I have used Batalax 010, 020, and Dunlop 220 and they in my opinion suck. THe Z6 really smoothed out the "vibrations" at the bars. Happy to hear you are ok.
HMS1
HMS1 is offline   Reply With Quote
Old 09-26-2005   #5 (permalink)
I wonder if some of that vibration may come from the excessive cupping on BT010/020's? Perhaps other brands as well.
I found Metzler Z6's and Avon ST45/46's cup only slightly and even then only after 6k+ wear, thus much less vibration especially in low speed sharp turns.
birdwh is offline   Reply With Quote
Old 01-10-2006   #6 (permalink)
Tires, tires, tires. Try the Metzlers.
"The Glory of God is man fully alive."
narrowminded is offline   Reply With Quote
Old 01-10-2006   #7 (permalink)
Tooth's Avatar
Other Motorcycle: KLR 650
Once again I must show my ignorance....what is a tank slap vs dumping the bike?
Mark
Trophy 1200 (03)
KLR650 (08)
Speed Triple (04) gone
IBA 31120
Tooth is offline   Reply With Quote
Old 01-10-2006   #8 (permalink)
tank slap is when the handlebars start to jerk side to side, for no apparent reason. Can be violent enough to toss you.
My 900 has a slow speed zone, where if I'm down to below 20 mph or so, and take my hands off, it will slowly start the fun. But it's not consistant. I've never had any problems at speed, though, thank goodness.
porsche996 is offline   Reply With Quote
Old 01-10-2006   #9 (permalink)
My '95 showed some signs of tank slap coasting down from about 45 mph. In the long run, i snugged up the neck bearings and never had the problem since.
Life's too short to ride Jap bikes!
bigern2300 is offline   Reply With Quote
Old 01-10-2006   #10 (permalink)
Tooth's Avatar
I developed a very pronounced shimmy to an out right wobble on my Kawasaki at 40-45mph when I take my hands off the bars. I have also noticed the same on the 03 Trophy. Are you talking about tank slapping with good control of the bars or just and out right sudden loss of control. :cry:
Mark
Trophy 1200 (03)
KLR650 (08)
IBA 31120
thruxton tank slapper Treehugger Club Cafe 5 02-16-2008 11:20 AM
tank slapper triumphtimes Daytona Deliberations 14 10-09-2007 11:46 AM
Tank Slapper dman Club Cafe 23 09-17-2007 05:31 PM
'03 ST Tank Slapper perfectweb Sprint Forum 10 09-15-2005 05:07 AM
Tank Slapper tank protectors blipco Modifications & Workshop Talk 2 01-01-2005 12:20 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
