Hi, have question I have a 1996 trophy 1200
it has now developed a oil leak at the clutch slave
and the sprocket cover .
am i missing something am baffled oil , sprockets and
chain replaced 3 months ago need help thank you
There is a drain slot at the bottom of the bore in the sprocket cover where the slave cylinder fits. If the oil is coming from there it looks like the clutch push-rod seal is leaking.
The fix requires removal of the sprocket cover as the seal is pressed into the crankcase.
