Old 08-23-2005   #1 (permalink)
Riq
I am sure that this question must be old by know however I don't see it covered in the 16 pages on this forum.
So here it goes;
When you refer to a triumph 3 or 4 are you referring to the number of cylinders or is there a sequencing by year involved.
I ask as I purchased a 1996 trophy 1200 about a month ago and figure I had better increase my knowledge base.
One other question has to do with the preload adjuster for the rear suspension. It looks like I will need to remove the tank to access this. Is that the case.
Thanks in advance for any responses.
Rick
ps. I love the bike.
Who says once more can't hurt ?
Rick
Riq is offline   Reply With Quote
Old 08-23-2005   #2 (permalink)
Favorite Bike: Triumph Trophy
Other Motorcycle: Triumph Legend TT
Extra Motorcycle: Suzuki DL650
Number of cylinders
J Goertz
Birmingham, AL
Trophy4 is offline   Reply With Quote
Old 08-28-2005   #3 (permalink)
Riq
Thanks.
How about the preload portion?
Rick
Old 08-30-2005   #4 (permalink)
My '96 only has rebound adjuster at the bottom of the shock and the notched lock-ring for setting preload spring tension, also at the the bottom. Both can be reached -- with some difficulty -- from the backside in front of the tire. Might be easier with the rear tire off, but removing the tank uncovers nothing on my bike.
Has your shock been upgraded?
J Goertz
Birmingham, AL
The Trophy is no more GreenGoblin Trophy 5 09-16-2007 05:49 PM
68 Trophy decobike Classic, Vintage & Veteran 5 06-15-2007 03:03 PM
what I don't like about my Trophy uptown Trophy 7 04-10-2005 10:45 PM
Trophy or not??? mhanson Sprint Forum 3 07-22-2004 03:46 PM
The NEW Trophy Trophy 1 03-09-2004 11:39 AM
