On 2004-03-04 21:33, FrankTrombetta wrote:
Thank you, Jam nut?
For your response to my question. Does the modification you speak of give you enough flow with the engine modifications you made? Also, I didn't really understand the first sentence of your reply-7/8inch hole saw in the exit side of each exhaust. I will try to rig up the extension to drill out the baffle. Wish I could get a little more tone out of it at lower r.p.m.'s. I may try and search for used D&D's.
I'll bet your Triumph is a lot of fun to ride.
Frank
Its still a little restricted for my set up. The reason my head got polished was I have a valve stem leak under warranty. They removed the head to ensure no damage. While all the work to remove/replace it was covered under warranty, it only cost $200 for the head work. Still a good improvement over stock.
Sorry for the confusion, just drill out the baffle. No need to remove pipe from bike (drill from back side). I suggested using a hole saw rather than a drill bit because is cuts though the stainless steel sheet metal baffle better. Also less chips. A hole saw, if maybe that is a local term, is a small drill bit surrounded by a cup with saw teeth on the edge. The cup is the final hole diameter. Hope that helps.
