Digital Speedo for 1200 Trophy - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsOntario TourismNew BonnevilleMotorcycle.comMotorcycle.com Classifieds!
Old 11-18-2009, 10:53 PM   #1 (permalink)
Favourite Bike: 2009 Speed
Other Motorcycle: 2009 Sprint
Has anyone added a digital speedo to their Trophy. Just picked up a 2002 that was originally from the US that is in miles per hour and want to indicate in kilometers per hour. I can but don't want to do the conversion in my head on the road and thought adding a digital display would be the easiest.
Thanks
Bob
coatesbob is offline   Reply With Quote
Old 11-19-2009, 07:51 PM   #2 (permalink)
Thanks
You should see km/h on the same speedometer... on the inside of the ring.
At least on my US speedometer...
curiousmike is offline   Reply With Quote
Old 11-19-2009, 09:25 PM   #3 (permalink)
True, but my slightly aged eyes do not like the fine print.
Bob
Old 11-21-2009, 10:05 PM   #4 (permalink)
McQ
Favourite Bike: '99 Trophy-4
McQ's Avatar
Speedo for Trophy
I just put my wife on the back . . . she always tells me when I am going too fast!
On a more productive note, can the gauge be disassembled? (The obvious answer is that anything can be disassembled, but can it be reassembled again and still work, that is the real question.) Any competent laser engraver operator can make a new backplate for the gauge for you. You can find them at higher-end arts and crafts shows sometimes, selling real tiny wood carvings and/or personalized laser engraved nameplates and the like. Hell, I have a laser at work; if you can manage to get the backplate out and mail it to me, I can recoat your existing one and cut new numbers for you, as big as you want. I would do it gratis just because I would find it an interesting challenge.
Q
Last edited by McQ; 11-21-2009 at 10:18 PM. Reason: Expressing my feminine side and changed my mind.
McQ is offline   Reply With Quote
Old 11-21-2009, 10:36 PM   #5 (permalink)
Q
Unfortunately my wife has her own ride so can't let me know.
I'll check into the disassembly thing. If it does easily enough then I will try to find someone around here. Thanks for the offer though. Sounds as though the laser etching thing could be fun to play with.
Bob
Old 11-23-2009, 03:27 PM   #6 (permalink)
Favourite Bike: 2001 Triumph Trophy 1200
andyc740's Avatar
Try a bicycle Speedometer
Check into bicycle speedometers. They have a little magnet that mounts on the front wheel, a sensor you would attach to your forks or brake mounts someplace, and a wire that runs from the pickup to the speedometer unit that would mount on your fairing.
They're cheap, fairly rugged, can be calibrated to almost any wheel size and you wouldn't have to take apart your stock setup. Just make sure the max speed is high enough for your needs.
Most come with additional functions; trip meters, odometers, elapsed trip times, etc. Some wireless models are available, too.
Good luck!
Sometime third biggest liar in Texas.
andyc740 is offline   Reply With Quote
Old 11-23-2009, 05:32 PM   #7 (permalink)
www.trailtech.net. I run one on my street (barely) legal XR650R. Works great!
camo2 is offline   Reply With Quote
Old 11-29-2009, 11:32 AM   #8 (permalink)
Thanks, I have been looking at the bicycle ones and think that is the way to go.
Bob
Old 11-30-2009, 07:33 AM   #9 (permalink)
Favourite Bike: 95 Thunderbird; 96 Sprint
GeoffE's Avatar
Other Motorcycle: 82 Jota; 79 XS850
Extra Motorcycle: 72 BSA Rocket Three
Hi,
I don't know if this would be of interest to you? The theory could be applied to a Trophy - see http://www.triumphrat.net/photogalle...133/album1260/
Here is the Dakota site (which offer some other ideas too): http://www.dakotadigital.com/index.c...=cat/cat60.htm
Good luck,
Geoff
GeoffE is offline   Reply With Quote
Old 12-30-2009, 11:58 PM   #10 (permalink)
McQ
McQ's Avatar
Instrument Cluster on eBay
Tripped across this and thought of you Bob...Check out item # 260529468660. It's a KPH instrument cluster, new for $220.
Good luck and Happy New Year!
Digital Speedo Problem Hobgoblin Speed Triple Forum 22 08-27-2009 02:50 PM
Digital Speedo for Sprint 2008 Red st1050 Sprint Forum 58 03-31-2009 10:51 PM
Sprint RS digital Speedo not working JRSPRINTRS Sprint Forum 3 06-18-2007 06:35 PM
2007 Tiger digital speedo markhewins Tiger Workshop (archive) 1 03-21-2007 06:53 PM
Digital Drive Speedo Upgrade for pre-O2 DEcosse Daytona Deliberations 4 09-30-2006 12:39 PM
