fuel lines - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 11-06-2009, 06:10 PM   #1 (permalink)
johnnymo's Avatar
Other Motorcycle: Triumph Street Triple
fuel lines
Took my tank of today to get a look at the the stuff below (air filter, coils etc) and noticed that there was only one fuel hose going from the fuel tap to the carbs. The other was attached to the fuel tap but cut to about 6 inches and blanked of at the other end.
One of the previous owners is responsible - but why would they do this and what effect would it have on the fueling of the bike?
Image can be viewed here:
http://www.flickr.com/photos/bother1/4081598484/
You can lead a horse to water but a pencil must be lead.
Last edited by johnnymo; 11-06-2009 at 06:11 PM. Reason: corrected spelling mistake
johnnymo is offline   Reply With Quote
Old 11-07-2009, 03:58 PM   #2 (permalink)
Favourite Bike: 2000 Trophy
BlueTrophy's Avatar
Other Motorcycle: 2004 Daytona 955i
One is for the ON position and the other is for the Reserve position. Is the petcock in the On position and is the smaller vac. hose attached to the petcock and to the #3 carb?
BlueTrophy is offline   Reply With Quote
Old 11-08-2009, 10:10 AM   #3 (permalink)
johnnymo's Avatar
Ah - OK. The petcock is in the ON position and the vac line is attached to the #3 carb. Does that mean that the reserve is redundant currently?
I will be renewing all the hoses anyway - thanks for the reply.
Old 11-08-2009, 10:21 AM   #4 (permalink)
BlueTrophy's Avatar
Most likely. it will not work. there shold be a plugged line at the carbs as well.
Old 11-08-2009, 04:40 PM   #5 (permalink)
Favourite Bike: My '02 Trophy 1200
ervdrvr1's Avatar
johnnymo,
First, you don't say what year or size your Trophy is.
I believe all the 900's have a single fuel line from the tap to the carbs. 1200's have two fuel lines from the tap to the carbs.
If yours is a 900, then the fuel tap may have been replaced with one for a 1200, if that is the case....no prob if one of the lines is blocked off.
Hope this helps,
Erv
"Life is tough, but it's tougher when your STUPID!" John Wayne
ervdrvr1 is offline   Reply With Quote
Old 11-08-2009, 10:53 PM   #6 (permalink)
BlueTrophy's Avatar
Did not know that. Thanks Erv.
Old 11-18-2009, 06:21 PM   #7 (permalink)
johnnymo's Avatar
Erv - its a 1999 900.
Thanks for the replies.
where do the fuel lines go doc Maintenance & Workshop Talk 6 03-28-2009 10:52 PM
Fuel Lines, IAC Lines GearHd6 Daytona Deliberations 0 05-20-2008 06:20 PM
Fuel Lines operators1 Trophy 2 06-30-2007 09:09 AM
'96 fuel lines, must be a better way! DBR0051 T3 Sport / Touring Forum 3 05-06-2007 12:10 AM
T3 OEM fuel lines Skullza T3 Sport / Touring Forum 9 04-25-2007 01:07 PM
