Rejetting for D&D Exhaust? - Triumph Forum: Triumph Rat Motorcycle Forums
New BonnevilleHonda Powersports Motorcycle.comMotorcycle.com Classifieds!Ontario Tourism
Old 11-02-2009, 01:24 PM   #1 (permalink)
Favourite Bike: Trophy 1200
I have a 2001 Trohy 1200 and I put on a set of D&D Exhaust. It is backfiring now when I release the throttle. Anybody having this problem. I called D&D and they said that I should not have to rejet. I am thinking differnet though. I like the D&D exhaust but don't want to hurt my Trophy's engine.
Bigdawg78387 is offline   Reply With Quote
Old 11-02-2009, 03:01 PM   #2 (permalink)
Is it popping or really back firing, meaning loud?
I've have read on the twins site that the stock exhaust is so quiet that it could have been popping some before but not noticeable because the stock exhaust is so quiet.
And, you might be able to do some adjustments for improvement without re-jetting.
Others out there might have more knowledge and be more specific.
Anyone?
why II is offline   Reply With Quote
Old 11-02-2009, 04:16 PM   #3 (permalink)
re:
It's popping. Like one of those big ole redneck trucks.
Old 11-15-2009, 12:03 PM   #4 (permalink)
Favourite Bike: my 02 Triumph Trophy BBBB
MIKEYLIKESIT's Avatar
I had the same problem. my problem was that the clamp would not get tight enough to seal the exhaust so i was sucking in cold air when i got off the throttle making the popping / backfiring. i got some high temp gasket maker/sealer and put it around the pipe before i slid it together and tightened the clamp. wipe away the excess and let it cure. that fixed my problem anyway. so, D&D said you dont have to rejet? i never talked with them, but i was told you do have to. let us know if you get it.
2002 Triumph Trophy
PGR # 126703
MIKEYLIKESIT is offline   Reply With Quote
Old 11-22-2009, 05:56 PM   #5 (permalink)
Favourite Bike: '99 Trophy 1200
Other Motorcycle: '07 Big Dog Pitbull
Extra Motorcycle: '06 Speed Triple
I didn't have to rejet when I used to have D&D's. And yeah, it sounds like you have a leak where the cans meet the head pipes.
Clever quote goes here
rat2tymes is offline   Reply With Quote
Rejetting... Is it necessary SMJoe Twins Technical Talk 9 03-21-2009 05:44 PM
epco exhaust, rejetting tuning help hardway01 Twins Technical Talk 2 09-17-2008 05:39 PM
Rejetting? NewOldSkool Twins Technical Talk 3 07-21-2007 03:46 PM
Yep it does need rejetting I think FlyBri Twins Technical Talk 1 07-06-2007 12:57 PM
Rejetting DrRocket Maintenance & Workshop Talk 5 12-18-2003 06:59 PM
