replacing rectifier - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-01-2009, 06:00 AM   #1 (permalink)
johnnymo's Avatar
Other Motorcycle: Triumph Street Triple
replacing rectifier
Hi folks,
Just got myself a 1999 Trophy 900 and it has broke down on me after first ride, approx 100 miles. Recovery mechanic reckoned it was the rectifier that needed replacing. Dont have the Haynes manual yet, so can you tell me where the rectifier is located on the bike?
Also any tips on best places to look for replacement part in UK?
Thanks
johnnymo is offline   Reply With Quote
Old 11-01-2009, 09:47 AM   #2 (permalink)
Slow down.
Give us the symptoms of the breakdown.
Don't start replacing parts or tearing that girl to pieces just yet.
Search this site(trophy only) for similar breakdowns.
Carry on!
"The Glory of God is man fully alive."
narrowminded is offline   Reply With Quote
Old 11-01-2009, 10:45 AM   #3 (permalink)
johnnymo's Avatar
Thanks for the reply.
The symptoms were the engine cutting out on me as i was slowing down coming up to a set of traffic lights. Then it refused to start again - battery was flat. The mechanic has noted on his paperwork 'Suspect regulator/rectifier - charging 11.30V'.
Just put the battery back in after a charge and it started OK. Is 11.3V low? What is the ideal voltage?
Old 11-01-2009, 05:46 PM   #4 (permalink)
DEcosse's Avatar
Those type of regulators in the automotive-style alternators typically fail in a 'high' mode, rather than low.
i.e. when the rpm is increased the output voltage continues to climb, instead of being 'regulated'.
First off check the fuse - that is the most likely issue as to why your battery is not seeing the charge voltage.
(I'm not sure which fuse it is exactly, on your model - should be either 30 or 40A fuse)
With your engine running, you should see more than 13.5V at least across the battery terminals. When you increase the engine rpm it may change slightly, but should never go over 15V max (and more likely less than that)
T'Rat.net BOTM November 2009
Old 11-02-2009, 09:38 AM   #5 (permalink)
johnnymo's Avatar
Hi DEcosse,
Thanks for the reply. I checked the fuses and they are all OK. Got a long journey tomorrow, London to Glasgow, hopefully trouble free. I'm hoping that giving the battery a full charge will do for now to get me home and i can investigate further then.
Old 11-02-2009, 12:39 PM   #6 (permalink)
DEcosse's Avatar
Originally Posted by johnnymo View Post
.... Got a long journey tomorrow, London to Glasgow, hopefully trouble free. ....
Johnny, please check the actual volts at your battery with the engine running - if you are not getting at least 13.5V, DO NOT GO!
Your battery will never power your bike for that whole trip and if your alternator is indeed only feeding it with 11.3V it will not re-charge while running.
Rectifier on 06 Sprint?? stinger Sprint Forum 20 11-18-2008 09:07 PM
Rectifier issues? Strife Daytona Deliberations 7 09-11-2008 02:50 AM
Where to buy rectifier/regulator the955iman Maintenance & Workshop Talk 4 08-16-2007 05:28 AM
D600 Rectifier garfield_2k Triumph SuperSports 0 03-16-2007 10:38 AM
Rectifier Blownfuse Classic, Vintage & Veteran 10 10-04-2005 03:20 PM
