Removal of front wheel / fork - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-28-2009, 03:47 PM   #1 (permalink)
I need to replace the seals on the forks, I have never really worked on a bike before. How do you remove the front wheel and then the forks.
doctor j is offline   Reply With Quote
Old 10-28-2009, 10:29 PM   #2 (permalink)
Favourite Bike: 99 Trophy 1200
Mark62's Avatar
Other Motorcycle: 79 Honda CB750F
Jack front tire off ground. I use a floor jack with a block of wood to get front tire off of the ground.
Remove forward fender.
Remove calipers NO NOT APPLY FRONT BRAKES.
Loosen pinch bolts (4) that face forward below the axle.
Insert phillips screw driver in 1/4 inch hole in axle and remove nut.
Slide axle out, noting position of spacer and speedo drive.
Remove back half of fender and clear any other items that might attached to forks.
Pay attention to how high your forks are above the triple trees.
Loosen pinch bolts on triple trees.
Apply WD-40 on forks between triple trees and slide forks down.
Good Luck
Mark
Who is going to reseal the forks?
Mark62 is offline   Reply With Quote
Front wheel removal on '03? ChazzyB Tiger Workshop (archive) 7 05-12-2008 12:55 PM
front wheel Removal?? Boriqua Twins Technical Talk 2 08-13-2007 10:45 AM
Front Wheel Removal bluespeed Twins Technical Talk 4 07-29-2006 05:41 PM
Fork Gaiters with no wheel removal danbike Twins Talk 18 05-08-2006 01:58 PM
Front wheel removal. Saigon5 Sprint Forum 15 03-26-2005 05:31 AM
