very rattley 1200 trophy... - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Honda PowersportsNew BonnevilleMotorcycle.comSportbikeTrackGear
Old 10-18-2009, 02:52 AM   #1 (permalink)
Newbie
Favourite Bike: 900 Trophy
Other Motorcycle: 1200 Trophy
Hi guys, wondering if someone can throw a bit of light on a possible problem.
I have had a 1994 900 Trophy for the last 12 months and reckon it's a great bike. The wife and I are going to be doing some touring this summer so I have just bought a 1996 1200 Trophy.
The 900 has like zero rattles from the engine or transmission when it's running but the 1200 clatters like crazy at idle but the rattles seem to disappear once over 1500-2000 rpm. There is also oil dripping from the airbox breather pipe. Runs ok though, no misses or anything and no smoke from exhaust.
Thoughts welcome. Thanks.
Kev 03/04 is offline   Reply With Quote
Old 10-18-2009, 12:40 PM   #2 (permalink)
Favourite Bike: 99 Trophy 1200
Mark62's Avatar
Other Motorcycle: 79 Honda CB750F
The rattle is normal. The oil dripping from the breather is probally that the oil is over-serviced.
Mark62 is offline   Reply With Quote
Old 10-20-2009, 11:21 AM   #3 (permalink)
Favourite Bike: Triumph Trophy 1200
Oil in the airbox is due to a fault within the engine, mine had suffered it from new and was fixed under warranty just before I parted with cash. A non return valve passing? Eventually it fills the airbox up faster than you can fill the sump.
Malc in Brum is offline   Reply With Quote
Old 05-14-2010, 12:41 AM   #4 (permalink)
wannatrophy's Avatar
Extra Motorcycle: Harley Dyna Low Rider
Per trackandrace.com workshop for the Trophy 1200 the rattle could be from balancer(s) needing adjustment.
wannatrophy is offline   Reply With Quote
Old 05-14-2010, 09:56 AM   #5 (permalink)
Favourite Bike: 2007 Bonneville "Muriel"
bobstretch's Avatar
Other Motorcycle: 1997 Trophy 900 "Maggie"
It may be the alternator bolt
...1200 clatters like crazy at idle but the rattles seem to disappear once over 1500-2000 rpm.
If your "rattle" is just noise, and not vibration, then this may help. If the "rattle" is both noise and vibration, this is not your culprit.
My '97 900 was very loud and rattlely at start/idle when I first got it - the dealer said it was normal due to the straight cut gears. The noise "went away" at about 2000 RPM but always returned when I slowed. After reading this forum I believed it to be a sheared alternator bolt. Sure enough, it was. Had the bolt/shaft replaced and the bike is now very quiet at start/idle. Night and day difference: just scan for topics on "alternator shafts" and you will find a lot of info on it.
Not much I can help you with on the oil issue, haven't experienced that as yet.
Good luck!
bobstretch is offline   Reply With Quote
New on here with a 96 trophy 1200 Jessechop Trophy 1 04-10-2007 10:01 AM
Trophy 1200 bgfootball67 Trophy 7 08-13-2006 12:32 PM
1200 Daytona vs. 1200 Trophy? ElJugador Triumph, Models & Dealers 1 07-13-2006 01:25 PM
Trophy 900 or 1200??? Suncoast Trophy 7 06-12-2006 12:58 PM
where can i buy a trophy 1200 bobh Trophy 10 04-07-2005 05:42 PM
