Super Sidecars Favourite Bike: Vincent Comet
Posts: 53 Other Motorcycle: AJS M 18 1946 Extra Motorcycle: BMW R 100 RT1, R60/7
Faring gaps in the mist
The faring has two flimsy brackets holding it out form the cylinders, they can be re-bent to adjust the lower part and take out any inward bowing. If the gap is off around the tank it's probably due to the tank slipping on it's two mounting bolts underneath the bracket in back. They live in slots that allow the tank to be adjusted if the whole bracket is removed - a little will look like hell from above.
Understand also that the faring is a stressed skin design: if you loosen, but don't remove all the screws you can push it back into shape and tighten up again. This might work.
Another, more serious, problem could be the front spider having gotten warped by the fall; did the front piece crack, or the mirror break? They're tricky but far from impossible to straighten, takes measuring from a common and imaginary center point between the upper front legs.
Cheers,
Zaphod
