I was told by a VERY GOOD Triumph mechanic,just to pour the entire gallon in when you change oil. The amount of .05 gal isn't significant and will not hurt a thing.I've been doing that since the first time I changed oil,have 54000 miles on my '01 1200 with no ill effects.If you do that,and have let all the old oil drain,then a full sightglass is no problem.Can't comment on the bafflectomy as mine has had aftermarket mufflers since I got it.(wanted it to sound like a motorcycle instead of a sewing machine).As for your warm up question,mine has always taken a couple minutes of slow idling with the choke on before it races.As long as you let it warm up properly before riding this shouldn't be an issue.Enjoy your Trophy.
Those who danced,were thought to be quite insane by those who couldn't hear the music.
