1200 - oil pressure issues at idle - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Honda PowersportsSportbikeTrackGear
Old 09-27-2009, 01:37 PM   #1 (permalink)
Newbie
Hi All, I have a 98 1200 Trophy with less than 7K on the clock.. so hardly used. Anyhow, I have an issue with the engine oil pressure warning light coming on at idle. It only happens when the engine is hot, i.e. engine fan is controling. When idling, the oil light starts to flicker. The hoter the engine the brighter the warning light. If I blip the throttle, the light goes out imediately, but as so as she returns to idle it lights back up again. I have set the idle speed at 1200, but that doesnt seem to cure things if the bike is idling in London traffic on a hot day. Oil has been changed and levels checked. All good. As there are no issues when the bike is cold or at normal running tempreature, the local dealer suggest changing the pressure switch, but I am sceptical. Any thoughts please..??? Thanks, Andy
ADB955i is offline   Reply With Quote
Old 09-27-2009, 10:59 PM   #2 (permalink)
Favourite Bike: 2000 Trophy
BlueTrophy's Avatar
Other Motorcycle: 2004 Daytona 955i
I thought the oil light on the Trophy was a level indicator light. I may be mistaking this for my Yamaha. Hopefully someone will correct or confirm this.
BlueTrophy is offline   Reply With Quote
Old 09-27-2009, 11:28 PM   #3 (permalink)
Favourite Bike: '96 Trophy 1200
FasTriumph's Avatar
Other Motorcycle: 2012 Bonneville T-100
Funky Electrics
When my bike gets hot I get the pulsing oil light. The couple times it happened this summer it was 90 degrees F and I was trapped in stop and go traffic. When I was able to get going and cool the motor, the pulsing lights disappeared. My oil level has not moved a milimeter so I just wrote it off to funky electrics.
John F
1996 Trophy 1200 BRG
2012 Bonneville T-100 Phantom Black & Graphite
FasTriumph is offline   Reply With Quote
Old 09-29-2009, 09:30 AM   #4 (permalink)
Favourite Bike: 99 Trophy 1200
Other Motorcycle: 2003 Yamaha FJR 1300
My 99 with 58000 miles does a similar trick. When hot, the oil light comes on at idle. The hotter it gets the higher the revs have to be to go out, up to 1900 RPM sometimes. I have purchased another switch, with the longer shaft to put an Oil Pressure guage on. The book says there sould be 40lbs at 4500(?)RPM at operating temp. I'll get around to it one day.
Goody is offline   Reply With Quote
Old 09-29-2009, 04:05 PM   #5 (permalink)
Newbie
Thanks for the advice. I was beginning to wonder if I had the only 1200 that did this little trick.. Now I know better. Thanks again..
Old 09-29-2009, 06:07 PM   #6 (permalink)
The instrument panel icons are known to act up. My temp. lite would appear faintly and pulse with the turn signals. I'd positively check the pressure, though.
"The Glory of God is man fully alive."
narrowminded is offline   Reply With Quote
Old 09-30-2009, 09:27 PM   #7 (permalink)
Mark62's Avatar
Other Motorcycle: 79 Honda CB750F
The usual cause is a bad/poor ground for the indicator lights. There is a modification to the lighting wires that is less than an hour fix (or two beers). I do not have the repair link anymore due to a dead then resurrected computer. But the repair is for adding a wire to the ground circuit off the connector plug to frame.
The main thing it is not a low oil pressure problem, but wires.
Mark
Mark62 is offline   Reply With Quote
01 Trophy 1200 Oil Pressure? What oil pressure? andyc740 Trophy 0 08-23-2009 10:43 PM
oil pressure issues crazywelder72 Classic, Vintage & Veteran 20 06-08-2009 05:25 AM
Idle issues dogeddie Twins Technical Talk 14 04-29-2009 04:06 PM
Crankcase Pressure Issues robnobrakes Twins Technical Talk 14 05-20-2008 02:49 PM
Oil pressure/level issues Foxee Tiger Workshop (archive) 7 09-01-2005 03:19 PM
