Trophy tank, electrics question on fuel sender - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comNew BonnevilleSportbikeTrackGear
Old 09-22-2009, 07:48 PM   #1 (permalink)
Favourite Bike: 02 Thunderbird
Ahoy; I have a 02 Thunderbird, but acquired a Trophy tank - year uncertain, but from a 900 - after checking that with some modification (there was a TB frame sitting nearby, luckily) it could be made to mount.
Now, the Trophy tank has a fuel level sender - two conductors. My dash is currently all digital, and I'd prefer to not add an analog guage. I -suspect- that it probably connects to ground on one conductor, and the other passes through a meter to 12v - or perhaps the meter's inline with the ground, either way.
My questions are this, then: what's the basic config? Which conductor goes to ground, which to the meter? If any of you are so willing, could you hook up a voltmeter in place of your analog guage, and give rough readings? (Ideally full, midlevel, empty)... I'm hoping that a properly spec'd digital voltmeter might take the guage's place.
Also, are there any third-part caps which ditch the need for the key? (I have the key, but would prefer to not need one for this task)
shoggot is offline   Reply With Quote
Fuel Tank Sender tigg-ted Tiger Chat 6 07-28-2009 05:45 AM
Fuel Sender Lead Goes Where? SprintST_Yes Sprint Forum 5 12-18-2008 06:20 AM
help- fuel sender-955 injected jabrady1234 Speed Triple Forum 0 06-21-2006 01:20 PM
How does a Trophy fuel tank vent? Mark62 Trophy 11 02-12-2005 08:08 AM
Sprint ST Fuel Line Question (fuel tank to/from fuel rail) Sprint Forum 7 01-26-2005 10:23 AM
