Stuck at 38 US mpg - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-15-2009, 11:17 PM   #1 (permalink)
Favourite Bike: 99 Trophy 1200
Mark62's Avatar
Other Motorcycle: 79 Honda CB750F
Stuck at 38 US mpg
I used to get 36 mpg.
I went to the KN airfilter and no change in MPG, but does run better.
Changed front sprocket to the 20 tooth (40 on rear).
This got me to the 38. With these changes I was hoping to bust 40.
Anymore ideas?
Mark
Mark62 is offline   Reply With Quote
Old 09-16-2009, 10:45 AM   #2 (permalink)
Favourite Bike: 2000 Trophy
BlueTrophy's Avatar
Other Motorcycle: 2004 Daytona 955i
Ride slower? Not fun...
BlueTrophy is offline   Reply With Quote
Old 09-16-2009, 12:45 PM   #3 (permalink)
Favourite Bike: 97 Trophy 900
andrewb's Avatar
You may want to change your rear ratio some more. As I understand it an even ratio 20/40 19/38 et al will wear it a repeatable and quick fashion. The same teeth hit the same rollers every revolution.
Maybe just a one or two tooth addition in the rear would break it up some.
As to mileage, carbs balanced? idle jets properly adjusted?, tires properly inflated? chain well lubed? Fuel lines solid and not seeping? carb floats adjusted? loose weight , remove stuff from panniers...
Lot's of little adjustments and tinkering can provide some good, solid MPG gains.
Definately YMMV,
Andrew
andrewb is offline   Reply With Quote
Old 09-20-2009, 02:16 PM   #4 (permalink)
Favourite Bike: Trophy
i have an 02 1200 with the 19/40 combo. the needles in the carbs were set at the number 2 position (from top, bike would not take throttle in number 1, too lean) with this set-up on a full day ride NEVER going over 60mph I can get 50/51 mpg. It is a very boreing ride. same set up commuting to work 12.5 miles away with bursts of 100 mph the bike gets 37 mpg. stop and go and never staying warm. there was a flat spot in the throttle off idle and when trying to pass anything so i went back in and raised the needles to the number 3 position. bike runs strong everyplace in the throttle position but this cost me a few mpg's. Now on a sane trip my best is about 48mpg and commuting is 35/36. it was worth the cost to get the bike to run better. these bikes CONSUME fuel. want to go fast, it will cost you. stay on the back roads and enjoy the ride and you will do better. my 2k trip to indy for the gp race (ride took me into canada and down left me with a 40mpg average). My fjr1300 with f.i. gave me at least 41 when commuting. I doubt triumph will ever produce the much wished for updated s/t bike, but if they do it will have f.i. then all this will be taken care of.
yanoosh is offline   Reply With Quote
Old 09-22-2009, 11:01 PM   #5 (permalink)
Mark62's Avatar
Being in the "family way" I just get to ride back and forth to work. It is 15 miles on a parkway with a 55 MPH speed limit.
It has been several years since I have had my carbs apart, so I am having a hard time visualizing the notches on the jet rod.
Old 09-23-2009, 07:31 AM   #6 (permalink)
Favourite Bike: 94 TroTona 900
Nobeard's Avatar
Are your carbs Mikunis? if so get some Keihins and check out the postings on the T3 Sport/Touring forum for lots of info about setting them up
Nobeard is offline   Reply With Quote
Stuck Gas Cap nobrot Twins Technical Talk 16 08-10-2008 09:01 AM
Fork Stuck themoose Twins Technical Talk 9 11-19-2007 03:19 PM
Stuck starter dogarajo Daytona Deliberations 10 11-12-2007 08:06 PM
Speedo stuck on 0 Stampy Triumph SuperSports 3 10-26-2007 12:45 PM
GAS CAP STUCK! joeknows Twins Technical Talk 15 05-25-2007 09:38 AM
