You might not have "vapor lock". Check that the vent tube off the bottom of the gas tank is not kinked, pinched or plugged. Any of these events will cause a vacuum in the gas tank and prevent gas from getting to the carbs.
If you have removed the tank for maintenance, it is easy to pinch the gas or vacuum lines against the spine frame of these bikes.
I had a similar problem where would run fine, then engine would die from lack of gas. It turned out that the vent tube attached to the bottom of the gas tank was just the slightest bit loose letting outside air into the tube. I pushed it fully back onto the vent nipple and used a zip tie to make sure that the vent tube was nice and tight on the gas tank's vent nipple. Problem disappeared.
A pin hole in the vent tube will also cause this problem.
Reason: More info
