Heavy Throttle Pull - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comSportbikeTrackGearMotorcycle.com Classifieds!
Old 09-12-2009, 10:31 PM   #1 (permalink)
mikurek's Avatar
Heavy Throttle Pull
My '96 1200 has a heavy throttle pull that causes my hand to hurt after long rides. I noticed there are two springs used to return the throttle. Can I just disconnect one of the springs?
mikurek is offline   Reply With Quote
Old 09-15-2009, 07:57 AM   #2 (permalink)
Favourite Bike: 97 Trophy 900
andrewb's Avatar
Have you taken it apart and inspected the cable? it could be frayed? Or perhaps just in need of a cleaning and lube.
andrewb is offline   Reply With Quote
Old 09-16-2009, 05:30 AM   #3 (permalink)
If the throttle works and it's simply a fatigue issue, consider a Throttlemeister cruise control.
"The Glory of God is man fully alive."
narrowminded is offline   Reply With Quote
Old 09-17-2009, 02:17 PM   #4 (permalink)
mikurek's Avatar
It's more than a fatigue issue, the pull is harder than it should be. I have ridden other Trophies that did not have the hard throttle pull. The bike has a Throttlemeister, but the vibrations and hard throttle pull at higher speed cause it to loosen. I rode 1200 miles to bring the bike home and my hand hurt for a week. I guess I need to pull the cable and lube it first.
Old 09-17-2009, 02:24 PM   #5 (permalink)
if you need a complete throttle assembly and cables I have one (10k on them).
camo2 is offline   Reply With Quote
Sputters when heavy on throttle menelfloss T3 Sport / Touring Forum 42 04-12-2011 09:54 AM
Pull over triumph Imperial88 Classic, Vintage & Veteran 5 09-27-2008 09:02 PM
Throttle Cable Options for straighter pull Never Bored Twins Technical Talk 8 01-03-2008 01:06 AM
snorkel, to pull or not to pull... opinions please (Bellmouth in hand) DJ Twins Talk 14 04-14-2006 07:48 PM
Thruxton throttle pull jbt56 Club Cafe' 3 02-11-2005 10:51 PM
