LED Bulbs - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-10-2009, 01:14 PM   #1 (permalink)
DDon's Avatar
LED Bulbs
Anyone converted their turn signal and brake lights to LED"s?
Any problems?
Worth the time and effort?
DDon is offline   Reply With Quote
Old 09-10-2009, 01:24 PM   #2 (permalink)
Favourite Bike: 2003 Sprint ST
Other Motorcycle: 2004 Ducati 999S
Extra Motorcycle: 1974 Norton Commando S3
All the lights on my '03 Sprint ST have been converted to LED. It is easy to do, but you have to replace the stock flasher with one designed for LEDs due to the low current draw. Worth it? I'm not sure how to estimate that. Motorcycle charging systems tend to lack much reserve capacity, so I wanted to reduce the load as much as possible.
The people who talk the most generally have the smallest results. Results speak for themselves. - Matt Mladin
Coroja is offline   Reply With Quote
Old 09-10-2009, 01:43 PM   #3 (permalink)
plenipotentiary
Supernova
Favourite Bike: Speed Triple
Catenaccio's Avatar
Other Motorcycle: CBR1100XX
Extra Motorcycle: Piaggio MP3
I went a different route. PIAA sells 23w bulbs for turn signals and brakes, running lights. I figured the extra incandescent intensity would show up better than LEDs. Don't know if they're better than LEDs, but they are brighter than stock.
I like to reminisce with people I don't know.
Catenaccio is offline   Reply With Quote
Old 10-24-2009, 02:44 PM   #4 (permalink)
Favourite Bike: trophy 1200
chuckless's Avatar
Other Motorcycle: gsx 750 gs 750
i,ve seen these new brake lights that flash when first aplide they look realy effective .
chuckless is offline   Reply With Quote
Old 10-24-2009, 03:35 PM   #5 (permalink)
Favourite Bike: 1999 Daytona 1200SE
JohnD's Avatar
Other Motorcycle: '08 Kawasaki Concours 14
Extra Motorcycle: a.k.a. GTR 1400
DDon,
Check out this post of Narrowminded this week. He not only switched his signals to LED's but also his mirror locations since he had to replace a mirror anyway after dropping his Trophy. Maybe you can PM him for specifics.
http://www.triumphrat.net/trophy/123...ce-please.html
I changed the tail light to LED's in a Yamaha Royal Star, I have since traded in on a Concours 14. The change in brightness was dramatic and made me feel much safer. It was a simple plug-in - simply remove the existing incandescent bulb and plug the LED into the same socket.
This is the site I purchased from. They don't seem to have a Trophy specific LED, but I believe there are some standard LED's that should work.
http://www.customdynamics.com/Yamaha_tail_retro.htm
JohnD is offline   Reply With Quote
Old 10-24-2009, 03:54 PM   #6 (permalink)
MotT3's Avatar
I changed a few bulbs etc recently and found the LEDs have moved on a generation..I got Superlux stop tails and side light bulbs....I swapped out my turn signals for some Oberon items but as mentioned will also need to change the relay ;-)
You can see here if you wish...http://mottleybiker.com/page33.htm
Cheers
Mot
www.mottleybiker.com
MotT3 is online now   Reply With Quote
Old 10-30-2009, 06:52 PM   #7 (permalink)
DDon's Avatar
Thanks for the info. I don't want to go through LED circuit upgrade, if I can get around it.
There are some very "inventive" people out there who have already invented the wheel and are willing to share the pros and cons.
That's what I like about this forum.
will these bulbs fit? longjohns Twins Technical Talk 5 05-07-2009 02:51 PM
LED Bulbs for Clock Bulbs Daveski UK Twins Technical Talk 8 11-08-2008 12:48 PM
Who knows a lot about LED bulbs? dazco Twins Talk 17 01-03-2006 04:14 PM
LED bulbs stinebiz Twins Talk 6 06-28-2005 09:30 PM
H4 bulbs - 100/80 instead of 65/55 jbhotchkiss Maintenance & Workshop Talk 12 04-13-2005 03:28 PM
