random loss of power - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-09-2009, 07:36 PM   #1 (permalink)
mikurek's Avatar
Hello,
I just bought a '96 Trophy 1200 and sometimes it will loss power briefly. When this happens I grab WOT and after a few seconds the power kicks back in. It is like the bike isn't getting gas or spark. If I don't WOT then the bike will coast to stop, like I hit the kill switch, but then it will start back up and run like a champ. Just wondering if anyone has experienced this type of problem and knows the cause.
mikurek is offline   Reply With Quote
Old 09-10-2009, 08:16 AM   #2 (permalink)
Favourite Bike: 97 Trophy 900
andrewb's Avatar
When this happened on my 1200, it was the ECU that was failing.
Others have had this problem and found it to be: (in no particular order)
coils,
pickup
bad grounds
bad spark plug wires
fuel lines between petcock and carbs
vacuum line from carb to petcock
bad plugs
When I fixed mine, I tried the easy stuff first, being in denial about the ECU. Because they NEVER go bad, but for me it was the ecu.
As always, YMMV
Andrew
andrewb is offline   Reply With Quote
Old 09-10-2009, 12:46 PM   #3 (permalink)
mikurek's Avatar
Thanks Andrew, I guess I need to start buying and replacing parts till I find the cause.
Old 09-11-2009, 10:38 PM   #4 (permalink)
Favourite Bike: 99 Trophy 1200
Mark62's Avatar
Other Motorcycle: 79 Honda CB750F
Don't spend any money yet. This sounds electrical. Clean the grounds before you spend a dime.
Mark
Mark62 is offline   Reply With Quote
Old 09-12-2009, 01:47 PM   #5 (permalink)
mikurek's Avatar
replacing fuel & vacuum hoses
I had a fuel leak which I fixed no the side of the road by cutting the hose shorter and reattaching; it's scary when gas is flowing onto the headers and steaming off. I'm going to replace all the hoses with automotive ones as suggested in other threads. I'm hoping this is also the cause of the 'random loss of power'. We shall see. While I'm at it I'll also check the GND wires.
Old 09-15-2009, 12:09 PM   #6 (permalink)
Favourite Bike: 1999 Daytona 1200SE
JohnD's Avatar
Other Motorcycle: '08 Kawasaki Concours 14
Extra Motorcycle: a.k.a. GTR 1400
Dame Mikurek, you were almost a "crisppy critter"! Let her cool down next time.
JohnD is offline   Reply With Quote
Old 09-17-2009, 02:12 PM   #7 (permalink)
mikurek's Avatar
might be fixed
Well I haven't had any problems since I changed the fuel and vacuum lines. I got ride of the filter inserts because there was a ton of crud in them and replaced with inline filters. I hesitate to say this it is fixed because the problem is random.
If it happens again, my next plan of attach is to shorten the optional factory alarm system ground wire, since that does not require any new parts.
I found this excellent site about the Trophy:
http://www.dirkmotard.net/Triumph%20Trophy%20FAQs.htm
Old 09-27-2009, 10:52 PM   #8 (permalink)
mikurek's Avatar
Fixed!
I'm happy to say that the new fuel and vacuum lines fixed by random loss of power problem.
Old 09-30-2009, 09:34 PM   #9 (permalink)
Mark62's Avatar
I am glad that I was incorrect!
Mark
Old 10-10-2009, 03:26 PM   #10 (permalink)
Favourite Bike: Vincent Comet
phavas's Avatar
Other Motorcycle: AJS M 18 1946
Extra Motorcycle: BMW R 100 RT1, R60/7
Random loss of power
Just for giggles, check your kickstand switch and return spring. They are known for losing contact when crudded up.
Cheers,
Zaphod
phavas is offline   Reply With Quote
Power loss between 4 and 6k rpm. new_user Daytona675 Forum 5 10-15-2008 05:54 PM
Big power loss bcade Speed Triple Forum 18 04-18-2007 09:39 PM
Power Loss wozman Twins Talk 3 11-12-2005 03:24 PM
lOSS OF POWER. kilda Hinckley Classic Triples 4 10-07-2005 05:16 PM
Trident power loss Maintenance & Workshop Talk 8 02-13-2005 07:19 PM
