fork oil - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 02-01-2004, 11:33 AM   #1 (permalink)
Anyone know how to change fork oil on an '02 Trophy, is there a drain plug under the axle? The owners manual states that the oil should be changed @12k, but it doesn't say how or how much or what weight
I can just replace it with the same amount that drains out, but it would be nice to have a ballpark figure to work from. :???:
stevent....."May the Goddess turn the hearts of those who hate us, if not their hearts then turn their ankles so we'll know them by their limping..."
stevent is offline   Reply With Quote
Old 02-01-2004, 11:33 AM   #2 (permalink)
Old 02-03-2004, 11:27 AM   #3 (permalink)
Favourite Bike: '98 Triumph Sprint Ex.
Extra Motorcycle: '02 Kaw Ninja 250
Remove the front wheel, remove the front fender. Then remove the large cap on the top of the fork leg, loosen the pinch bolts on the upper and lower triple trees (yokes), coat the legs that are going to pass through the yoke holes with a light coat of oil and gently pull the fork legs out.
Turn the legs upside down to pour out the old oil. Leave them upside down for a while to let them totally drain.
The refill is not measured in fluid ounces but mm's from the top of the fork leg. The measurement is made with a tool that looks like a big syringe with a flexable tube at the end and an adjustable rigid tube at the end of that. Excess oil is drawn out with the tool. It's inexpensive and can be had through any of the aftermarket catalogs and probably through one of the links here.
Any manual for your bike will give you that measurement (in mm's) and the correct weight of oil.
Anything else you need to know about this, fire away.
j98sprint
j98sprint is offline   Reply With Quote
Old 02-08-2004, 11:48 AM   #4 (permalink)
Thanks for the tips, I was afraid that was the case. Maybe while they're off I'll drill and tap a drain hole at the back of the forks. :-D
Fork Oil - Increasing viscosity and oil level? NikosR Sprint Forum 9 04-21-2007 05:12 PM
Fork oil loveTrumpet T3 Sport / Touring Forum 3 05-05-2006 01:51 PM
fork oil rash_powder Sprint Forum 2 04-04-2006 12:28 PM
fork oil bobh Trophy 3 09-23-2005 05:20 PM
speaking of oil...steamer fork oil amounts? flyintiger Tiger Workshop (archive) 2 02-22-2005 12:45 PM
