Old 06-06-2005   #1 (permalink)
Any body know if the idle screw needs to be set in a different position if the engine is run with the fuel tap set to prime instead of normal for a long time? I am assuming that it will need to be if the carbs have to work less hard to get the fuel through and not if there is no difference. (trophy 900)
Old 06-06-2005   #2 (permalink)
mnmrosen's Avatar
There is no difference. The vacuum draw on the engine is virtually the same, and the fuel feed is identical. It's all gravity fed thru the same line.
1996 Triumph Trophy 900
2003 Kawasaki KLX400SR
mnmrosen is offline   Reply With Quote
95 triumph 1200 fuel tap settings Kingjoey5000 Daytona Deliberations 4 01-30-2008 11:25 PM
Fuel Tap Pea_Fritter T3 Sport / Touring Forum 4 06-25-2007 06:23 AM
fuel tap bigbird T3 Sport / Touring Forum 5 01-14-2006 11:00 AM
Fuel tap EdC Modifications & Workshop Talk 24 03-24-2005 05:08 PM
'96 Sprint Fuel Tap GeoffE T3 Sport / Touring Forum 11 08-17-2003 08:46 AM
