Adding a top case question
I found an old thread from 2005 that said you can use a Givi adapter plate (E121) on the Triumph mounting plate and then use a Givi case on Trophies.
The Trophy mounting plates are hard to find (at least I seem to be having trouble). Is there a mounting plate from another Triumph bike from the same year(s) - 96 or 97 - that has identical attachment points as the Trophy that could be used on a Trophy?
Thanks
