Mirror disassembly - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
SportbikeTrackGearNew BonnevilleHonda Powersports
Old 06-07-2009, 07:43 PM   #1 (permalink)
Mirror disassembly
Has anyone tried to take a mirror apart? I've got the right arm for a mirror without the mirror and the wrong arm with the mirror attached. Do I need to pry the mirror out of its case to remove it from its arm? If I can remove the housing from the incorrect arm, hopefully I can then attach the housing to the correct arm. Sounds reasonable......
JD900 is offline   Reply With Quote
Old 06-12-2009, 09:57 PM   #2 (permalink)
HEY......I answered my own question! Yes you can take a mirror apart...the housing from the arm. The dealer wanted $120 for a new one. The used one I got that I thought would work cost $40. I just had to remove the housing from the arm and then place it on my existing mirror arm. NOthing that a really hot blow dryer, a ,screwdriver and a 10mm socket can't fix.
Old 06-13-2009, 02:37 AM   #3 (permalink)
Favourite Bike: Trophy 900
The Major's Avatar
Well done!
Amazing what is possible when we "give it a go"!
It may be a "Big Boys Toy" but it's cheaper than a mistress!!
The Major is offline   Reply With Quote
Disassembly Tip / Advice GrandPaulZ Vintage Technical Tips & Tricks 1 04-30-2009 01:21 PM
Need Help: Tach disassembly Dumluk Hinckley Classic Triples 3 01-12-2009 11:21 PM
Clutch disassembly TR5T Bonnevillain Classic, Vintage & Veteran 2 07-07-2008 09:48 AM
Need help with fork disassembly rminchi Twins Technical Talk 11 03-26-2008 09:45 PM
Disassembly of F3 Forks? Hawk Twins Talk 6 10-14-2005 10:39 AM
