Rear wheel removal 1995 1200 Trophy - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismHonda Powersports
Old 05-22-2009, 08:01 AM   #1 (permalink)
Newbie
Hi, I need to replace the chain and sprockets on my 95 1200 Trophy. I've never worked on a bike with eccentric chain adjusters before so before diving in I would appreciate a little advice. Basically a blow by blow guide to removal.
Obviously the rear caliper needs removing, the pinch bolts securing the adjusters need slackening off and the hex bolts that pass through the adjusters to the axle require removing - but after that does the axle need 'knocking through' the adjusters or do you remove both adjusters?
This is probably basic stuff to most but I just cant visualise how to go about it. I'm used to 70's and 80's japanese bikes with simple bolt and lock nut chain adjustment.
Any help would be much appreciated.
mustcleartheshed is offline   Reply With Quote
Old 05-22-2009, 08:27 PM   #2 (permalink)
Favourite Bike: 99 Trophy 1200
Mark62's Avatar
Other Motorcycle: 79 Honda CB750F
You are on the right track. Loosen the pinch bolts on ecentric, remove caliper and remove axle.
Mark
Mark62 is offline   Reply With Quote
1995 Trophy 1200 = needs rear shock Longdistance Trophy 5 12-15-2008 06:17 AM
rear wheel removal Anomoly Speed Triple Forum 2 08-04-2008 03:21 PM
1995 Trophy 1200 / Speed 4 conversion cockroach Trophy 2 09-16-2007 04:31 PM
Rear brake pedal---2002 Trophy 1200 Cross-Country Trophy 8 04-11-2007 11:54 AM
1995 Trophy 1200 Footrests Trophy 1 04-07-2004 10:50 AM
