| Trophy Trophy 3 & 4 - for all 900 and 1200cc models 1991- 2004 |
05-11-2009, 04:10 AM
Grand Prix 125 Favourite Bike: Triumph Tiger 800
Posts: 34 Other Motorcycle: Triumph Trophy 1300 Extra Motorcycle: Triumph Tiger
Improving fuel mileage
I read about guys that can get 50+ mpg out of the Trophy 900. Was just wondering how I can improve mine. My 96 Trophy 900 gets an average of 40 mpg. I have heard that you can drop some teeth on the rear sprocket. Was just wondering how much of a difference the overall power and fuel mileage would be if I were to change the gearing. Bike has almost 46000 miles on it if that happens to make any bit of difference to any suggestions. Also, how much would the sprocket change drop for RPMs at about 70 mph on the interstate? Thank you very much
05-12-2009, 05:28 PM
Grand Prix 250 Favourite Bike: Yamaha FJR1300AS
Originally Posted by TRIUMPH3FANMAN
... Also, how much would the sprocket change drop for RPMs at about 70 mph on the interstate? Thank you very much
Use my mph/rpm calculator, just change the numbers you want to (you'll have to check your handbook for your original sprockets, the gearboxes are all the same), press Submit, and see the results.
mcatrophy
'10 FJR1300AS [ex '06 FJR1300AS, '02 Trophy 1200, '01 Bonneville, '55 Tiger Cub]
http://atrophy.lock.net
05-12-2009, 10:25 PM
Supersport 400 Favourite Bike: 95 Trophy 3
Posts: 93 Other Motorcycle: KAW Quad Extra Motorcycle: CB 450 twin
Better mileage?
Hey, Ive got a '95 trophy 3 and it was my first sport touring bike .... I was raised on dirt. The first month I got 45-47 m.p.g. Then I got used to it...I get 35-36m.p.g. and have a heck of a lot more fun!!! I get 6000 miles out of a set of AVON Storm STs......I just met a lady with 97k on a yamaha 600 she gets 11k out of the same tyres!!! It's all in the wrist!!!
Once you go through the TRIUMPH door, all other doors look like walls!
05-12-2009, 11:14 PM
Formula Extreme Favourite Bike: 99 Trophy 1200
Posts: 592 Other Motorcycle: 79 Honda CB750F
Count the teeth on both of your sprockets. Your bike might be set up for aggressive riding instead of MPG. For best MPG go big in front and small in rear. (That sounds funny)
05-14-2009, 10:25 PM
SuperStock Favourite Bike: 1995 Speed triple
If the person who gets 50 Mpg is from the UK, then your 40 Mpg would be the same. As the Imperial pint (20oz) is 25% larger than the American pint (16oz) therefore both vehicles would be using the same amount of fuel per mile.
If at first you don't succeed, hit it with a bigger hammer
05-16-2009, 09:35 PM
Just rode from Dallas to El Paso and back to Dallas this past weekend. Average consumption was approx. 48.5 mpg.
1296 miles on 26.75 gallons.
I did change my sprocket set to 19/40 from a 17/44 that came stock on the bike ('96 1200).
1995 900 Sprint Nightshade
1996 1200 Trophy Merlot
05-17-2009, 02:04 PM
Supersport 400 Favourite Bike: T'bird/Trophy hybrid
Posts: 84 Other Motorcycle: Toad King Extra Motorcycle: XS650 Yam
gearing calculator
Thanks for sharing your gearing calculator, Mc, it is very kind of you.
Question, though, do you REALLY run 19/40 gearing?
The 92 Trophy I have just used as a donor bike for my Thunderbird/Trophy hybrid sidecar outfit had 18 and 45.
19/40 seems somewhat overgeared to me.
Reason: missing word
05-17-2009, 02:10 PM
From what I have read 19/40 was an offered gearing from the factory on the later Trophys. The 19/40 combo pulls real well and I have no problem when riding 2-up with all three bags. 2-up for me is less than 300 pounds though.
05-18-2009, 02:51 PM
The 19/40 was standard from (IIRC) 2001 for the 1200s.
A sidecar outfit would certainly need lower gearing than a solo, not so much for cruising (where you can always stick to a lower gear) but when moving from rest; the extra load is quite considerable, fighting the weight and the sideways pull.
mcatrophy
05-19-2009, 10:32 AM
250 Grand Prix Favourite Bike: Nighthawk CB650SC
Posts: 112 Other Motorcycle: '93 Triumph Trophy 900
I have two (likely stupid - sorry) questions.
Are the gear ratios essentially the same for the Trophy 900?
Am I right in thinking that you would get better economy at lower rpm for a given speed but that such a setup would result in less acceleration?
Many thanks for your help, Adam
