Factory Alarm - Triumph Forum: Triumph Rat Motorcycle Forums
New BonnevilleSportbikeTrackGearMotorcycle.com Classifieds!
Old 04-26-2009, 03:07 PM   #1 (permalink)
Other Motorcycle: 83 GR650 Suzuki
Question Factory Alarm
The other morning I was not able to disable the factory alarm on my 2000 Trophy using the remote (bad remote battery). I have now changed the battery and everything is working fine but I am wondering if there is a way of disabling the alarm for extended periods.
In the past when I have had to work on the bike I have disconnected the battery, closed the garage door and waited for the alarm to die - the neighbors really appreciate that!
I do not have the original owners manual so any help would be appreciated.
mcG63 is offline   Reply With Quote
Old 04-30-2009, 03:21 PM   #2 (permalink)
Favourite Bike: Modified Honda Hornet
millwallfcuk's Avatar
Other Motorcycle: Triumph Trophy
hi there,
i also have this problem when i don't use the bike for a few weeks. The fob basically won't work until i disco the battery and recon. Then the fob works to turn off the alarm siron.
wierd but it works.
millwallfcuk is offline   Reply With Quote
Old 05-01-2009, 05:56 PM   #3 (permalink)
Favourite Bike: My new Tiger of course:)
Thumbs up Kevh
Hi,
I'm assuming that you have the Triumph Veto alarm fitted.
OK, so the bike's standing there, alarm is armed and the red neon light on the rev counter is flashing.
Point the fob at the bike and press the circle button until the alarm beeps once.
Put the key in the ignition and turn it to the on position.
Press the circle button again until the alarm beeps twice. The red neon will now be constantly illuminated, and the alarm will beep every 15 seconds.
The bike alarm is now in service mode. You can remove the ignition key if you wish.
To reset the alarm, press the circle button with the key removed.
The instructions for the alarm are on an A4 sheet not the owners manual
Hope this helps.
WelshKev
kevh82065 is offline   Reply With Quote
Old 05-02-2009, 12:46 PM   #4 (permalink)
Thumbs up Service Mode for Alarm
Thanks for your help! Always impressed with the way everyone helps each other out on this site.
McG63
Triumph factory fit alarm bduke Speed Triple Forum 7 11-03-2008 07:58 AM
Factory Alarm LED????? drakewn Daytona Deliberations 8 04-30-2008 10:31 PM
03 Factory Alarm System Help? kuhlka Speed Triple Forum 3 04-30-2008 12:40 PM
Factory Alarm Opinions, Please singring Twins Technical Talk 1 11-14-2006 02:25 AM
Installing a factory Datatool3 alarm, 03 ST tbiller Sprint Forum 3 05-20-2006 12:03 AM
