Where does this rubber hose go? - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
New BonnevilleHonda Powersports
Old 04-18-2009, 01:24 PM   #1 (permalink)
I put my Trophy on the center stand last night after a ride, and this morning I saw a hose hanging down, not connected to anything! It's a bit under two feet long, 3/8" OD, 1/4" ID. I assume it's a vent hose, but where does it go? I see one from the coolant bottle hanging down,and another smaller one from around the back of the airbox. The bike seems to run fine, but it's not too comforting knowing it's not on there. Any ideas?
2002 Azure blue 1200, topbox, gel seat, heated grips, Clearview screen w/vent, throttlemeister
02Blue1200 is offline   Reply With Quote
Old 04-18-2009, 04:10 PM   #2 (permalink)
MotT3's Avatar
You have three, coolant, tank and battery. Sounds like battery to me, easy to check just lift up the battery and see if a hose is connected to the R/H side...?
www.mottleybiker.com
MotT3 is offline   Reply With Quote
Old 04-18-2009, 05:20 PM   #3 (permalink)
Favourite Bike: 2002 Triumph Trophy
Other Motorcycle: 1970 Triumph Tiger 650
Extra Motorcycle: 1999 Yamaha Virago 1100
Check your airbox; it has a drain tube for condensation etc. from the breather. There will be a "stub" on the bottom rear of the box if the hose has fallen off. Mine did, and it's a bit of a job to re-route it; once mine was clipped back on, I used a small hose that just fit snugly into it and snaked it down through the frame using it to guide the breather hose. I ran mine to the r.h. outside, near the battery drain; I believe the original ran down through the shock spring or very near it.
Good Luck: Jim
Jim Ballard
jimballard is offline   Reply With Quote
Old 04-19-2009, 03:36 PM   #4 (permalink)
Thanks guys. I will check both and let you know what I find.
Old 05-02-2009, 06:31 PM   #5 (permalink)
Just an update, it was the battery vent. I reattached and routed it in hopefully a good way, and I should be good to go! Thanks again.
gas coming from rubber hose under bike keithk Twins Technical Talk 3 07-28-2008 10:41 PM
Anyone an expert on Rubber - Not your sort of rubber, DaveM! RexxyPup Sprint Forum 12 06-24-2008 11:46 PM
Rubber Hose Rot johnO Sprint Forum 5 09-08-2007 09:12 PM
What is this rubber hose hanging between my bike's legs? poffypoffa Twins Technical Talk 5 11-15-2006 06:51 AM
HOSE / mystery hose bonnieamer1 Twins Talk 8 09-11-2005 02:04 AM
