From what I've read HIDs are 35w after the ballasts get things going. The light output is equivalent to 150w w/o the heat. There is a company in GB that manufactures a 55w HID conversion kit. I'll see if I can track it down.
Two downsides: in some states HID conversion kits are illegal because the refractor/reflector isn't designed for HID output (too much light scatter) and if you convert the high beam you have significant lag time until the bulb is at full brightness.
I like to reminisce with people I don't know.
