If I remember right. Large fuel lines go to left and right of petcock, they're shaped to fit. Small un-formed tube that follows fuel lines towards carbs, goes to the inside nozzle coming straight off the back. On my 900 it's really easy to pinch this one against the frame, be careful. Vent tube(right/rear underside of tank) hangs straight down, watch it doesn't get pinched in anything. Fuel gauge wire connecter, and your done.
Figure out a fix for that vacuum line for the petcock and you'll be a hero.
Carry on!
"The Glory of God is man fully alive."
