Time to ditch the airbox? - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismMotorcycle.com Classifieds!New BonnevilleMotorcycle.com
Old 04-07-2009, 03:54 AM   #1 (permalink)
Favourite Bike: Nighthawk CB650SC
Other Motorcycle: '93 Triumph Trophy 900
Hi guys,
For my next trick, I'm thinking of junking the airbox (I have a spare) and fitting cone filters. Anyone done this before? I expect to fit richer jets and wear earplugs, but anything else I should know about?
I'm not concerned about losing some low-rev torque; the Trophy has gallons of it. I'm doing it more for the sound; here in South East England there are loads of clueless car drivers just waiting to knock you off "sorry, I didn't see him".
Adam
gamsa is offline   Reply With Quote
Old 04-15-2009, 11:33 AM   #2 (permalink)
Favourite Bike: my 02 Triumph Trophy BBBB
MIKEYLIKESIT's Avatar
from what i keep hearing, the cv carbs on the Trophy will not work to well with cone type air filters. i have talked with a few bike mechanics as well as a couple of people here and they all say the same thing. on the other hand i've heard of a few people that have done it and they say it will work, so i dont know for sure. i was thinking of doing it myself just to get rid of that impossible air box but..... if you decide to do it, please post your results with pics too. i just noticed the year of your bike, not sure if you have the same carbs i got. dont know much about older Trophys. anyway good luck.
2002 Triumph Trophy
PGR # 126703
MIKEYLIKESIT is offline   Reply With Quote
Old 04-15-2009, 01:09 PM   #3 (permalink)
Yeah, I've got Mikunis whereas you guys will have Keihins. This gave me the idea http://www.dynobike.com/gallery/tech...y_900_pods.htm
Old 04-19-2009, 06:38 PM   #4 (permalink)
If only for the sound, how about super loud horns? There are some really effective compressed gas canister horns that not even Piaas can touch. You just replace the canister every so often but when you lay on the horn, they'll hear you in the Urals.
Halofaller is offline   Reply With Quote
Old 04-20-2009, 03:10 PM   #5 (permalink)
That's something I hadn't thought about and is probably a good idea, but what I'm really after is a constant, running noise. The sort of thing that would alert car drivers to your presence as you came up behind them.
I've got hold of some richer main jets for the Mikunis and will fit them after my exams end in mid May. Until then, the airbox stays =)
Old 04-20-2009, 03:30 PM   #6 (permalink)
MotT3's Avatar
A few of us over in the T3 Sport/Touring section are fitting pods, I am currently doing so too, most of us are going to Keihins at the same time to overcome MPG issues and the wear that occurs on higher mileage Mikuni's.
I too have heard that the CV's doesn't like pods but some people seem to have had some success so I thought I'd give it a go, I had a dyno run a while back as standard so I have something to compare it to when I do the swap...we'll see I suppose..?
Couple links to threads may help..?
http://www.triumphrat.net/t3-sport-t...and-tuned.html
http://www.triumphrat.net/t3-sport-t...keihin-cv.html
Cheers
Mot
www.mottleybiker.com
MotT3 is online now   Reply With Quote
Old 04-21-2009, 03:50 AM   #7 (permalink)
Thanks, that's really interesting. I may go to Keihins at some stage, but have bought some richer jets for the mikunis (as well as new tubes and needles) so will try them first. I'm not too worried about gaining a couple of mpg.
Probably time to pull the airbox off propforward Twins Technical Talk 10 10-31-2008 12:56 AM
Ditch your GPS, get yourself a Monarch ! Tbirdnz Biker Hang-Out 14 01-10-2008 09:25 PM
Girlfriend went into a ditch at 50mph KingStreetRat Twins Talk 20 10-17-2006 09:51 PM
ARRGH! SOB ran me into the ditch! Rickhoppe Hinckley Classic Triples 7 10-29-2005 10:08 AM
Airbox Leaking Big Time Hinckley Classic Triples 11 05-11-2004 06:51 PM
