Help for 1200 needed. - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-03-2009, 02:45 PM   #1 (permalink)
Favourite Bike: speed triple 1050
Other Motorcycle: KH 250 & KTM Rc8R 2011
The 1999 1200 is driving me nuts. Please help.
It misfires at most revs.
No 1 2 &3 plugs are O.K. but a weak colour but No 4 is black.
I cleaned all the lines.& filters.
Fitted new rubber carb manafolds.
K&N filter
New plugs
New coil
new leads.
I bought the coil and leads to solve this problem.
Anyone got any ideas?
Meanwhile i will strip the carbs again and clean out the pilot jets again.
Thanks in advance for your hepl!
Mike
1977 KH250.1992 TROPHY 900,1996 TROPHY 1200,
1996 PBR MONKEY BIKE 160cc,
1998 SPRINT 900,2007 SPEED TRIPLE 1050.
Mike The Bike is offline   Reply With Quote
Old 04-03-2009, 06:02 PM   #2 (permalink)
Fixed?
As the problem is with No4 I tried to remove the floatbowl still whilst on the bike. No luck so I took off the top cover to discover the spring was not seated properly.
I fixed it in place, and sacked my helper."nothing is my fault".
The bike runs but still has some poping now and again. Im going to give it a good run and see what happens.
Mike
Old 04-04-2009, 09:23 AM   #3 (permalink)
Favourite Bike: 99 Trophy 1200
Mark62's Avatar
Other Motorcycle: 79 Honda CB750F
Sounds like you are on to something. Since you had the carbs a part did you syncronize them? If the grips are "buzzy" at speeds then you really need to sync the carbs.
My 1200 pops when cold.
Mark
Mark62 is offline   Reply With Quote
Old 04-04-2009, 02:15 PM   #4 (permalink)
Favourite Bike: Nighthawk CB650SC
Other Motorcycle: '93 Triumph Trophy 900
My 900 pops a little on the overrun, but I do run it rich (bottom clip on the carb needles).
gamsa is offline   Reply With Quote
'01 Trophy 1200 buying info needed twstm Trophy 5 08-19-2008 10:38 AM
1994 Daytona 1200 head needed nicktulloh Daytona Deliberations 0 06-10-2008 05:15 AM
95' 1200 parts needed - Petcock, Rectifier & Solenoid nydesmo Daytona Deliberations 1 04-13-2007 05:55 AM
95' 1200 parts needed - Petcock, Rectifier & Solenoid nydesmo Trophy 0 04-12-2007 10:08 AM
1200 Carb Help Needed nydesmo Daytona Deliberations 13 03-28-2006 07:28 AM
