Motorcycle.com
Old 04-16-2007   #1 (permalink)
Favorite Bike: Triumph Thruxton
itcha's Avatar
I wanted to buy myself a torque wrench for when tinkering with the bike. What is the best size to get to cover most of the settings on the Thruxton. I also see in the Haynes manual that they use Newton Metres.
Would a 3/8 torque wrench be the best size?? Would there be any need for a 1/2 wrench. I've never owned one of these suckers as if you couldn't tell.
Cheers.
itcha is offline   Reply With Quote
Old 04-16-2007   #2 (permalink)
I have two, one 3/8" drive (10-40Nm) & a 1/2" drive (60?-200Nm) this seems to cover most things, I find that I use the 3/8" drive most. But I'm the sort who sets the drain plug on my car with a torque wrench.
using a intel imac
Dickie2679 is offline   Reply With Quote
Old 04-16-2007   #3 (permalink)
Ditto, I use a 3/8 drive wrench for the lower torques and fit a 1/4 converter for use with larger sockets. I also have a 1/4 wrench for higher torques. Having seen the pain experienced by those who have stripped threads and being a bit new at maintenance I have been sticking to the figures. There is a good printable .pdf file of torque settings in the downloads section.
Farnham1 is offline   Reply With Quote
Old 04-16-2007   #4 (permalink)
Favorite Bike: Scrambler
panthercity's Avatar
Other Motorcycle: R1150RSA
Extra Motorcycle: R1100RSA
IIRC, the axle nuts are the only "normal" maintenance items that you'll need a 1/2" drive torque wrench for. A 3/8" should handle the rest.
Keep in mind that a torque wrench is most accurate at the center of its range. Consequently, you're better off buying a range of good torque wrenches if you are going to be doing this for a while.
One of my mottos, "A man can never have too many tools or too many bikes. He can have too small a garage, but not too many bikes and tools."
Bob AMA #162726 LPR #54
`02 BMW R1150RSA
`06 Triumph "Scrambled"
panthercity is offline   Reply With Quote
Old 04-16-2007   #5 (permalink)
I used one of these in my last job
Torque wrench
very good, but expensive (£1000+) dropped them a few times, but that's how it is with tools :razz:
using a intel imac
Old 04-16-2007   #6 (permalink)
You really need at least two of them, a small one for most stuff and a bigger one for axle nuts, cylinder head bolts, etc. Torque wrenches should typically only be used from about 20-90% of their range; below 20% they're inaccurate and near their upper limits there's the risk of damaging them.
In the US, the torque wrenches made by Precision Instruments are quite nice, and can be bought from several online tool dealers. This is the company that supplies the wrenches for Snap-on (who then double the price).
joeswamp is offline   Reply With Quote
Old 04-17-2007   #7 (permalink)
Favorite Bike: 2004 Bonneville America
Bryan's Avatar
Other Motorcycle: 1976 T140V {Bonneville}
Extra Motorcycle: 68'YCS1E,71'CT90,82'XL80
I have several click wrenches 1/4", 3/8" and 1/2". I have one 1/2" flex wrench with an analog scale that comes in very handy and two 3/8" wrenches with an analog dial. I use all of them for different applications. A 3/8" and a 1/2" should take care of your needs quite well. I use the click wrenches when tightening bolts/nuts in places where I can't read the analog types. I like the analogs because they give a smooth even torque.
Bryan is offline   Reply With Quote
Old 04-17-2007   #8 (permalink)
SpeedyPete's Avatar
I got the smaller 1/2" drive as a b-day present a few years back and have rarely been able to use it. If I had the 3/8" on the other hand....
Bottom line, a well stocked toolbox should have both and the larger is probably more useful. They are expensive little critters though.
P
I have heard the song of the Sausage Creature!
SpeedyPete is offline   Reply With Quote
Old 04-17-2007   #9 (permalink)
Favorite Bike: Speedmaster
This is the one I bought from Sears.
Do you want to be the player? Do you want to be the string?
http://ratokc.com
rwright is offline   Reply With Quote
Old 04-18-2007   #10 (permalink)
5bassman's Avatar
inch pounds instead of foot pounds?
2005 Triumph Bonneville Black
5bassman is offline   Reply With Quote
Torque Wrench Gwiaz Twins Technical Talk 6 08-03-2007 11:32 AM
torque wrench CCR Modifications & Workshop Talk 11 06-03-2007 08:12 PM
torque wrench bung1 Twins Technical Talk 9 01-02-2007 07:28 AM
torque wrench ? Colonel_Dorkus Twins Talk 10 05-28-2006 02:14 PM
Best Torque Wrench? MaxH Modifications & Workshop Talk 22 06-07-2005 10:15 AM
