Motorcycle.com
Closed Thread
Old 10-03-2006   #1 (permalink)
I just changed out a tailight and now I'm blowing fuses when I apply the brakes but the parking light still works (if that makes sense). The old light was a 12V/21/5W and the new smaller light is a 12V/23/8W. I tried to find a smaller 5W light but I couldn't find a stop light bulb.
Can I use a larger fuse? Will I die on the side in a ball of flames?
Any suggestions?
PolockJoe is offline
Old 10-03-2006   #2 (permalink)
Make sure the bulb connector is fitted back in properly. I did this to when I had to tighten my turn signals that the dealer left very very loose when fixing my flat.
Anyway, the bulb needs to go in a particular way. I blew 2 fuses before rechecking my handi work and noticed the little black plastic contact was not seated properly back into the hole. Mine has a sort of key fit to it. Then I put the ***** bulb in wrong. running light was very bright and brake was very very non-noticable. reversed it and working fine now.
The key is that contact point. Make sure it is seated properly. I had mine kind of jammed in there and it was shorting out.
Hope this helps, and pertains to your issue. I am after all a newb here still.
Soccermasta is offline
Old 10-03-2006   #3 (permalink)
Never thought of that....I'll check it out tonite. THX
Closed Thread
06 ST BLOWING FUSES? airrider03 Sprint Forum 3 03-14-2007 06:18 AM
blowing fuses sandblaster Hinckley Classic Triples 19 12-11-2006 06:04 PM
Keep blowing fuses? RickyT Sprint Forum 1 11-10-2006 11:23 PM
S4 blowing fuses sangsters Triumph SuperSports 6 09-28-2005 06:13 PM
Fuses blowing sangsters Modifications & Workshop Talk 6 09-27-2005 10:19 AM
