Motorcycle.com
Closed Thread
Old 08-08-2006   #1 (permalink)
D9
Vendors
D9's Avatar
WARNING - do not read or view this post further if you are offended or upset by the sight of scooters, messy *****-filled garages, the mundane trappings of suburbia, or eccentric Bonneville owners with sharp tools.
Below are some pics taken while bobbing fenders & flyscreen. No pics of
rear fender, but it was done the same way as the front.
Tools are what you see - nothing special. The narrow-handled extension on
the Dremel really allowed delicacy during the cutting maneuvers - highly recommend it.
BTW, don't even THINK about getting anywhere near a dremel without total eye protection - full goggles.
The cutting wheels used are the fiberglass reinforced type, approx 1". The wheel used to
bob the flyscreen was slightly larger, about 1 1/4" diameter.
Also recommend high quality 1/4" masking tape from any automotive paint supplier - it really
helps to have a re-positionable tape that allows smooth curve contouring, makes it easier
to get the shapes smooth.
No marking or drawing was required, instead all "lines" were formed and refined with the tape - which also
served as an essential high contrast visual guide while cutting.
For the symmetry-challenged, one could easily make a simple paper template and use that as
a tape guide. I did use a piece of tape or two, applied horizontally, to check for symmetry. Once the tape was giving me exactly the curve I wanted, it was pressed firmly in place.
The cutting "line" is on one edge of the tape, depending on where you
want your curve to begin and end.
After positioning and repositioning, eyeballing, checking, and finally burnishing down the tape, safety goggles on, cutting wheel mounted securely, I started in with the dremel at highest rpm setting, moving very slowly, back and forth about an inch at a time, until a reasonably consistent groove was slotted all the way across the fender, then kept making smooth, light, back and forth passes until the wheel started to cut through. Care is required as the wheel begins to cut all the way through, as it tends to grab edges and jump. As seen in the photos, two hands are used at all times to cut and brace the tool.
After cut-through was complete, I used fine metal files to smooth the path, remove any ragged metal, and contour edges and just worked until I was satisfied with it and the edge felt reasonably close to the painted factory edge. With medium or dark colored fenders, it helps to
put a white piece of paper behind the fender to help fine-tune the curve, as the paper will help you to see any roughness or unevenness.
I purchased s small bottle of touch-up color at a local auto parts store - not a perfect match, but I'm only intending to brush about a scant 1/32" on the edge of the fender. I used PPG DX330 as as surface prep/area degreaser prior to painting.
Taped the mask line for the touch up, shook the bottle, and brushed away, let dry for an hour, brushed on another coat, done.
To bob the inboard edge (engine side) of the front fender, I first removed the four bolts securing the fender to the fork, removed the fender, turned it around, bolted two of the four fork bolts back in place, pushed a piece of wood between the tire and the underside of the fender to help reduce excess movement and vibration, then proceeded again to cutting with the dremel. Certainly could have done something different to hold the fender, but this worked well, and it was all right there, so that's what I did. I did let most of the air out of the front tire to allow easier removal and replacement of the bolts that secure the fender to the fork.
I seriously considered removing the chrome fender stays, but decided to leave them on for now - plenty of material left if I decide to take off more later.
Flyscreen was handled the same way - on the bike, with care. After cutting, rather than filing, I sanded down and smoothed the edge with wet 220 grit automotive sandpaper on a rubber block - once again, just slowly working it to a smooth, even edge that feels good to the fingers. Probably should gently wet sand again with some 400 grit prior to painting, although the edge pretty much disappears as the flyscreen is made of black plastic.
Overall, the changes are subtle but pleasing to me. The bobbed flyscreen IMHO is an especially nice mod - I don't have a good pic of it yet. Overall I'd say the bike looks slightly leaner and cleaner, somehow lighter on it's feet - or rather, tires.
I'd highly recommend practicing a bit on a piece of 1/16" steel, whether or not you've worked with a dremel previously, to get a feel for material resistance and feed rate while using the cutting wheel. And again - wear full coverage eye protection - the dremel really throws off a lot of debris at an impressive velocity.
Special thanks to my lovely wife and my oldest son for being patient and
helping take pics.
Cheers,
D9
[ This message was edited by: D9 on 2006-12-27 21:05 ]
Bracketology
D9 is offline
Old 08-09-2006   #2 (permalink)
OK, I like it! Good job.
"A skittish motor-bike with a touch of blood in it is better than all the riding animals on Earth." --T.E. Lawrence
http://oldsport.home.comcast.net/photos/oldsport.gif</IMG>
oldsport is offline
Old 08-09-2006   #3 (permalink)
Favorite Bike: 02 bonneville
bonniegirl's Avatar
looks great. much like watching one of the surgery shows on tv!. i'm bobbed too, front & back.
bonniegirl-vel
bennington triumph bash may 31, june 01 2008
bennington vt
www.armchaircommando.org/bennington
bonniegirl is offline
Old 08-09-2006   #4 (permalink)
Loxpump's Avatar
Hey D9,
Great post. One of the best instructional Mod posts I have seen. If you can't do it yourself after reading this you never will. Seeing them side by side before and after is fantastic. Shows how slight changes can make an overall improved appearance. Especially the fly screen. Keep that Dremel handy.
Stop Global Whining!
Semper Fi!
Loxpump is offline
Old 08-09-2006   #5 (permalink)
D9
Vendors
D9's Avatar
Thanks for the comments - I'm thinking about making a custom hat from the piece of the rear fender that was removed, putting some graphics on it - something along the lines of "Bonneville Fender Bobbers - Short is Beautiful" or some such, and raffling it off here - will keep ya'll posted.
Lox - I have fresh cutting wheels, your new bike, wherever it's found, is up next...
Cheers,
D9
Bracketology
D9 is offline
Old 08-09-2006   #6 (permalink)
Retired Legend
sweatmachine's Avatar
Nice post, good pictures too! I just got rid of my Triumph Flyscreen b/c I couldn't stand looking at it any more, I think you made it look 300% better. Nice job on the fenders too, I never thought about bobbing them TO the struts, most lose the struts and hack the fenders. Good lookin' bike.
thanks for the post! :gpst:
alright alright alright
Bonnie cafefighter!
sweatmachine is offline
Old 08-09-2006   #7 (permalink)
That's HOT...especially because I have a blue one with a flyscreen too!
DC
Bonnecuse is offline
Old 08-09-2006   #8 (permalink)
Ridge's Avatar
I made it past the warning about the filled garages (I was expecting something like Keef's :razz: ). Glad I did too!
Wow! That is quite an exhibition of skill and bravery! Thanks for the tutorial. I love the final product. That front fender looks sportier even with the brackets.
Great Work, D9!
~Ridge~
BIR #188
My Photo Gallery
Ridge is offline
Old 08-09-2006   #9 (permalink)
cobra935o's Avatar
Yeah, looks good. I like to do everything myself, but I dont know if I am up to cutting straight lines yet, hehe.
Nathan
cobra935o is offline
Old 08-09-2006   #10 (permalink)
Great write-up! I've been pre planning to do this, and it's nice to see that it can be done as easily as i anticipated.
mybluett is offline
Closed Thread
Bobbing fenders NewOldSkool Twins Technical Talk 13 05-21-2008 05:13 PM
Bobbing metal fenders (hacksaw or dremel) dave1068 Twins Technical Talk 25 05-21-2008 04:57 PM
Factory flyscreen mod for headlamp access DIY D9 Twins Technical Talk 0 07-23-2007 10:36 PM
Bobbing rear fender... REVOLT Twins Talk 8 04-21-2007 05:21 AM
Bobbing rear fender? d2mini Twins Talk 7 03-09-2006 09:33 PM
